Home > Technical (L322) > FBH - a Range Rover story |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 |
So
23rd Jan 2017 8:33pm |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Interesting read - and good luck !
23rd Jan 2017 9:03pm |
Charlyfarly Member Since: 26 Jun 2015 Location: Warwickshire Posts: 210 |
No offence guys but it must have taken you as long to type this out as it did to fix (?) the problem.
23rd Jan 2017 9:09pm |
So, having made the decision that repairing my own unit if it needed it, and having ordered a lucky pump, following some online instructions, I set about stripping the unit. There are plenty of tutorials around, suffice it to say it's quite straightforward. Disconnect and de-route the glow plug cabling first and watch that fuel pipe! Once you have the unit carefully separated, you're left with the heat exchanger:-
23rd Jan 2017 9:26pm |
You make a good point. I figured this may help someone somewhere along the line, as there's not much in the way of fullfat specific tutorials that I could find. 2007 Vogue TDV8 with 255/55/20's fitted |
23rd Jan 2017 9:29pm |
Good point JB.
23rd Jan 2017 9:37pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
You guys do know, that with say, an iPad/phone, you can just use the mic symbol, and dictate your long winded passage, whilst say, on the loo, or in the bath. Making quick work, and ammmending any mistakes after. In this private space, you don't distract other room users, who think you are mad talking all funny. Also...in the toilet, your long wind-ed passage, 'issue' is dealt with! |
24th Jan 2017 12:23am |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Great stuff Johnnyboy, appreciate all the typing! Actually it does take ages to type up this stuff and sort and upload pictures (see my thread on heated seat repair - probably took me most of an evening)
24th Jan 2017 6:40pm |
Thanks for that - restores my faith somewhat. I didn't decide to do a write up to be a sleeping aid for people!
24th Jan 2017 7:06pm |
MM - have you tried via IID tool? Or tried the power off and on reset? 2007 Vogue TDV8 with 255/55/20's fitted |
24th Jan 2017 7:08pm |
No worries bud
24th Jan 2017 7:16pm |
So
24th Jan 2017 9:11pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Really good write up JB. Well done so far.
25th Jan 2017 7:40am |
@John, from memory the resistance was 0.4 ohms, but it was within the advertised range.
25th Jan 2017 10:06am |
