Home > Maintenance & Mods (L322) > Rear LED relay |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
would it be easy for you to swop the off side box to the near side and check if it all works ok....if so it will a matter of obtaining a similar one .. |
26th Jan 2017 11:17am |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
If the fog lights not right they probably haven't wired in a ballast.. I've just fitted a set and they worked plug and play apart from warning messages on dash and fogs being half on.. simply wired in resistors and ballasts and their perfect... |
26th Jan 2017 11:18am |
ruffy Member Since: 11 Jan 2016 Location: North Yorkshire Posts: 70 |
Thanks for the quick responses. Swapping the other one over is a good shout, however I don't know which wire is which as they're not marked - will I do any damage with the 'give it a try' approach?? Don't know anything about resistors and ballasts, all I can say is the lights work fine - apart from the flickering mainly on start up and the one fog light obviously. A new relay costs about 5 so not much outlay if it solves the problem. 1982 SIII 88” diesel
26th Jan 2017 11:46am |
