Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
Great write up, and looks like a "cheap" fix if the pump hasn't been damaged
20th Oct 2016 6:38pm |
PHG Member Since: 20 Oct 2016 Location: Marple Posts: 15 |
Just an update for all those people who find this thread whilst researching their own transfer box issue. Mines a 2008 FFRR TDV8.
28th Oct 2016 10:37am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
JP Automatic Transmissions near Bristol advertise that they stock parts for the DD295 transfer box
Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
28th Oct 2016 3:51pm |
Bodsy Member Since: 10 Mar 2011 Location: Shropshire Posts: 45 |
Just going through the refurb of a spare transfer box I have. No info on removing the bearings on this thread, are they all fit to 'stop' or need to be a set depth?
9th Feb 2017 12:19am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Special transfer box oil... isn't that a posh name for fully synthetic hypoid oil? unless there's an LSD in the later boxes, then it's LSD oil that's needed Yesterday I couldn't spell Engineer... Today I are one!
9th Feb 2017 10:02am |
Hi Bodsy the bearings seat in their stops nicely, no need to worry about pushing them too far. One thing that caught me out (amongst others) was the cir clips on the input and output shafts press in, into the shaft not out. 2015 SDV8 AB
9th Feb 2017 10:22am |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
really good write up, looks like a pretty straight forward rebuild. |
9th Feb 2017 10:42am |
Hi, the write up is all down to RRPhil, I just used it to help me with my noisy transfer case, still had a though time even using RRPhil's write up 2015 SDV8 AB
9th Feb 2017 10:47am |
Useful info, thanks. I had been looking at them and figuring out that they can only really go in as just not enough space to pick it out. Bearing kit arrives tomorrow, so will see how it goes! |
9th Feb 2017 8:07pm |
DD295K bearing kit arrived from Advanced Factors this morning, so off out to have a play... |
10th Feb 2017 12:02pm |
Most of the bearings replaced, decided not Tibet change the one at the eng of the selector shaft as I'm pretty sure that'll be relatively low impact low useage.
10th Feb 2017 5:51pm |
Autocorrect! Belville not belvoir.
10th Feb 2017 5:54pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
INA stuff for the Land Rover 300tdi timing pulleys are made in Slovakia. |
11th Feb 2017 1:05am |
Looking at the diagram in the manual, the two springs appear to be stacked in series between the circlip and the bearing.
11th Feb 2017 2:59pm |
