Home > Technical (L322) > Air Suspenion Issue |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Paul,
12th Feb 2017 12:15pm |
Paul1234002 Member Since: 06 Oct 2015 Location: Manchester Posts: 32 |
Simon,
12th Feb 2017 12:28pm |
Alistarh,
12th Feb 2017 12:30pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
As I have stated many times, once the compressor stops pumping it inevitably ends up in a new compressor.... if your going to fit new piston rings the time to do it is before the compressor plays up..... normally once the compressor gets weak the cylinder is scored, and as it's a chemical liner, there is nothing that can be done other than replacement Yesterday I couldn't spell Engineer... Today I are one!
EAS inactive message can often be caused by low battery voltage....
12th Feb 2017 12:35pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Paul1234 . not sure about your diagnostic but most can read resovoir pressure.. the scorings not noticeable in the chamber.. |
12th Feb 2017 12:36pm |
Alistar, There was no scoring at all.
12th Feb 2017 12:46pm |
An ffrr (L322) is like a baby... it will often spit out its' dummy for no reason, and when there is something wrong, it doesn't always have the correct vocabulary to convey the problem.....
12th Feb 2017 12:53pm |
Paul,
12th Feb 2017 1:10pm |
Buddy if your EAS is working when you've reset the system, with out fault, then it's not the EAS system that's causing the message in the first place... plugging in your box of tricks doesn't magically repair worn out components.. Your obviously new to Range Rovers, and haven't gotten used to their quirks... the biggest problem is the all singing and dancing computer is actually stupid, and lacks the messages to convey the real problem, so it has a panic throws up no end of faults, the new owner spends thousands of pounds on new parts only to discover that there is still a problem.. eventually you will get to the route cause..
12th Feb 2017 1:12pm |
Thank you all for your guidance and wisdom.
13th Feb 2017 11:19am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
If you are lucky the relay will come with it!
13th Feb 2017 6:55pm |
http://www.ebay.co.uk/itm/LAND-ROVER-RANGE...3641.l6368
13th Feb 2017 7:27pm |
New air compressor & Relay turned up today. Fitted and all is well.
15th Feb 2017 6:04pm |
