Home > Maintenance & Mods (L322) > Deployable side steps playing silly :censored: |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 |
Not sure if the current inclement weather had crudded up the mechanism but my side steps were either really slow going in or out , sometimes staying in or out and generally looking a little out of kilter.
12th Feb 2017 3:47pm |
Apologies for the initial expletive - thanks admin for covering it up CURRENT : FFRR 2012 4.4 TDV8
12th Feb 2017 4:02pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
fitted by dealer ?.....if so take it back...
12th Feb 2017 4:08pm |
Stan , fitted by dealer but well out of any warranty.
12th Feb 2017 4:39pm |
Nice one - I'll get some lithium grease and give it a go CURRENT : FFRR 2012 4.4 TDV8
12th Feb 2017 5:57pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 442 |
Just freed both mine off. Easiest way is to remove the step, 4 small Allen bolts. Disconnect rod to rear hinge, 8mm bolt. Place rags or cardboard on floor under hinge. Squirt copious amounts of wd40 to hinge pins whilst working the hinge in and out by hand, sure I must have worked it a hundred times but it freed off and works a treat now. Once free a good soaking of engine oil followed by a smear of grease |
12th Feb 2017 11:45pm |
rr driver Member Since: 09 Dec 2013 Location: london Posts: 181 |
I had this issue on my previous RR, was under warranty, they said either Battery issue- ( not strong enough) or motors on the steps. In the end they changed the motors of the steps. Never had problems again. 2011 5.0SC Santorini Black
Well the lithium grease hint worked a treat! CURRENT : FFRR 2012 4.4 TDV8
17th Feb 2017 5:46pm |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
^ Glad to hear it!
17th Feb 2017 5:52pm |
