Home > Maintenance & Mods (L322) > L322 4.2 s/c gearbox problems please help! |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
By far the most common issue with the 6HP26 is faulty solenoids.
6th Dec 2016 4:27pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
I did as above earlier in the year. I sent my valve body to a firm in Luton (can't recall the name at the moment), they tested it and found some faults which they repaired. I reassembled with new seals, sump and oil and then reflashed the software using my IID tool. Almost 12 months later and the problem I had (similar sounding to yours) hasn't reappeared. |
6th Dec 2016 5:29pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 719 |
not the same car but I had my TD6 box reconned with a new torque converter 4 years ago and paid just shy of £2000 at an auto box specialist with 2 year/24,000 mile warranty (whichever came first) |
6th Dec 2016 5:56pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
I've had exactly the same issue on a similar car and gearbox, luckily I became one of Phil's guinea pigs. All of the problems were down to one solenoid. Yes, just one of them!
6th Dec 2016 7:48pm |
Mclarke155 Member Since: 06 Dec 2016 Location: Birmingham Posts: 3 |
Thanks for the response guys! RRphil, if I was to remove the mechatronic unit, send it off for testing is there a cheap way of re flashing the gearbox software now I've reset the adaptations like a fool? cheers |
7th Dec 2016 6:20am |
If you have an IID tool you can do it with that, for a small extra fee. |
8th Dec 2016 5:40pm |
jonbaobao Member Since: 12 Jun 2014 Location: Taiwan Posts: 6 |
Thanks to the contributors. This has solved my problems by IID TCM flush and replaced solenoid valves. |
15th Feb 2017 6:10am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
15th Feb 2017 10:36am |
Great news! |
15th Feb 2017 10:39pm |
This fixed my problem couple of years ago. Now it is coming back intermittently. Reset fault and will go back to normal for a month or two. Now it also reads bank 1 rich sometimes. Can the bank 1 rich code and the transmission fault related? |
9th Apr 2019 2:51pm |
