Home > General > 2010-12 MY buying advice
Page 4 of 5 <12345>
theres one on topix i believe..... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #427221 10th Feb 2017 7:11pm
GGDR
Here is my updated table for 2011 options v standard - as best I have been able to put together (with a little help from the forum!)
2012 is most likely different as each MY they played with what was standard v option. I hear they reduced the standard items for 2012MY.
When you're in buying mode you're reading tons of ads that list out hundreds of items that are std like Isofix etc etc. But the dealers just don't know the difference between std and an option. Eg my car has surround cameras AND the 1200w stereo, neither options were advertised. (Naturally, I didn't point those out) So I found the table useful - especially as a 1st timer to get my head around all the gadgets. Then I used it to compare different cars I was considering.
Once you have the VIN you can find out exactly what it has via Topix.
Post #427269 11th Feb 2017 10:09am
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
That's pretty helpful, thanks. I read that the Westminster was an edition limited to 300 vehicles worldwide but elsewhere I read it was the new name for the base model in some markets. Is that correct?
I'm currently looking in the German market for a 2012 but the selection is limited compared to the UK and also very spread out across the country.
The 2011 press release states that the vehicle has Brembo brakes but photos I've seen of '11 and '12 models seem to all have Range Rover on the calipers. Are they actually de-badged Brembos or were Brembos an option?
Actually, the press release states "Brembo-based" so maybe they are de-badged. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #427305 11th Feb 2017 3:37pm
CS
In the UK the WM was a run-out model for the 322, essentially a Vogue with ventilated seats, 20" wheels, dual view screen, Harmon Kardon system and various trim items. The brakes are of the Brembo type but are badged 'Range Rover'. Only Range Rovers since 1988
Post #427313 11th Feb 2017 4:25pm
FrankRizzo
Cheers, CS Thumbs Up
Is there any visual cue that indicates whether Adaptive Dynamics is fitted? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #427319 11th Feb 2017 5:00pm
CS
According to the 2011 brochure all models have adaptive dynamics. Only Range Rovers since 1988
Post #427322 11th Feb 2017 5:35pm
FrankRizzo
In 2012 it was only standard on the Autobiography. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #427323 11th Feb 2017 6:14pm
my 2012 westie has 'adaptive dynamics' so i'm sure all 2012 and possibly 2011 FF's have it.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #427336 11th Feb 2017 9:07pm
GGDR
It's in the 2011 Owners manual. Not mentioned as optional so I believe std on all 2011s. I don't have a 2012 manual to check, may have been charged to option. Also varies by country....
Post #427338 11th Feb 2017 9:42pm
mjdronfield
Mine has it. There are electrical connections on the top of the shockers if you open the bonnet..... you can't see the big nut etc like you can normally..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #427357 11th Feb 2017 11:41pm
FrankRizzo
Test drove a '12 model yesterday and realised that the speedo and rev counter have switched positions on the digital display. I'm used to them being the other way around (rev counter on the right, speedo on the left) as in my '08 car. Is there a setting that allows you to swap them around? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #427926 15th Feb 2017 9:02pm
mjdronfield
Don't believe so....not much you can do with the display to be honest....LR should have utilised it a bit more as far as I'm concerned..... can't even get sat nav directional arrows on it..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #427927 15th Feb 2017 9:08pm
no you cant change the positions but you can change the speedo from mph to kph very easily which is handy for us brits that take the FF abroad.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #427940 15th Feb 2017 9:34pm
FrankRizzo
I test drove an 11MY Autobiography yesterday and it had everything except adaptive cruise control. I thought it was standard on the Autobiography so I was surprised that it was not fitted. At least, I assume it was not fitted because the two additional gap increase/decrease buttons were missing on the steering wheel.
However, the seller (an indie dealer) tried to tell me it was fitted and that the buttons were not necessary because gap control was all handled automatically. This sounded like bs to me, am I right?
I noted the VIN but Topix says "VIN not found" so I've asked the dealer for it again in case I made a typo. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #428220 18th Feb 2017 11:04am
mjdronfield
The indie is wrong, the buttons allow you to increase or decrease the gap that is leaves to the car in front. Looks like it's not fitted then.
I think the Autobiography is a standard car, with some options from the Autobiography options list chosen, meaning it gets the badge and other AB stuff too. So if the base car was a Vogue with AB options added, it won't have ACC as the Vogue never had ACC. If it was a VSE with AB options, it would have it. Am I right here? Sure the AB have a model they are based on trim wise.....might be wrong...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #428225 18th Feb 2017 12:08pm
Page 4 of 5 <12345>
