Home > In Car Electronics (L322) > Can an intravee give you faults?
alistairh
Finally got mine installed and I've now noticed an under voltage fault for both headlights and a dimmer potentiometer open circuit fault? Weren't there before it was installed so I'm curious if it's due to the intravee as I've altered drl's ect with it..
Post #427308 11th Feb 2017 3:57pm
alistairh
And more? Also got headlight undervoltage faults.. only started when I fitted intravee and enabled headlights to come on when I pressed key fob to open? I'm going to try unplugging unit then see if they come back..
Post #428406 19th Feb 2017 7:26pm
miggit
Anything that connects to the ibus has the power to throw up faults... I'd unplug the unit and see if the faults go Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #428489 20th Feb 2017 12:32pm
alistairh
Unplugged it last night.. zero faults today! At least I know what's causing them.. I think it's something todo with the headlight activation on unlock...car was fine before I enabled that feature.. cheers buddy
Post #428493 20th Feb 2017 1:08pm
miggit
So reset the options to factory, plug in you intravee and see what happens... you can live without the headlights on opening... FYI I found that even if the car was unlocked, pressing the open button on the key triggered the puddle lamps and interior lighting too, enough to ensure that I didn't fall in a pothole!! Yesterday I couldn't spell Engineer... Today I are one!
Post #428515 20th Feb 2017 4:10pm
alistairh
Reset the lot. Plugged back in zero faults. Decided to try and activate lights again and faults are back.. just shows how easy the system throws a fault.. now deactivated and all good. Thumbs Up
Post #428517 20th Feb 2017 4:23pm
miggit
Is there a need for headlights on opening? If so you could trigger a relay to power some spots / led's with the interior lights and have them cancel with the ignition Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #428519 20th Feb 2017 4:28pm
