Home > Technical (L322) > Electronic parking brake
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
My first real issue with the TDV8 Vogue SE in 7000 miles of ownership...and I fear it is my own fault. Sad
Decided to give the low ratio a go, just to keep things from seizing up....but stuck it into reverse and forgot to take the parking brake off....BIG bang! Shocked I had thought the EPB automatically released if the vehicle was set in motion by the driver?
Nothing wrong inside either of the parking brake drums...all as it should be...but I am getting the screech of death and Parking Brake System inoperable message. If on an incline, it may work normally momentarily only to then start to roll downhill...screech and error message rapidly following. Drums also now getting hot. I assume I need a new module and it will be a pig to fit? Or is it possible it has snapped a cable that can be replaced (even if LR won't sell separate cables)?
EDIT: Just tried the emergency park brake release which appears to reset things. However, when I then operate the park brake I get the screech until I either deactivate it or it goes into fault mode. It does seem like something has come adrift rather than completely broken?
Post #430706 10th Mar 2017 3:53pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Have you an IID ? It has a option to free off the brake and reset 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #430726 10th Mar 2017 5:40pm
Zeb
Not yet no. Could I reaet the EPB by a battery disconnect instead?
Post #430728 10th Mar 2017 5:56pm
kbald
I dont think the parking brake will reset with a battery pull. There is a procedure you do to reser the handbrake when you change the discs etc which involved driving it an pulling on the handbrake (or actually pulling the electric leaver) when driving. Not sure if it will help or do more damage though. Do you get tension on both cables going to the brakes when its pulled on?
Post #430732 10th Mar 2017 6:13pm
Zeb
I have a suspicion that I am only getting tension on one side so will investigate that possibility further tomorrow.
Post #430734 10th Mar 2017 6:27pm
dolph34
There is alot about the screeching and how to resolve it online . Its mostly on the Discovery forums but im not sure if the FFRRs handbrake module / mechanism can be reached as easily. I had mine replaced recently and the rear suspension had to be dropped. I think the screeching is caused by the screw used to pull and release the cables goes past its maximum. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #430747 10th Mar 2017 8:36pm
Zeb
Hmm...not a job I can do with axel stands then!
Post #430749 10th Mar 2017 8:47pm
dolph34
Lol , you might need a swiss army knife and a hammer, just to cover all the nases Laughing 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #430752 10th Mar 2017 9:08pm
Zeb
Sorted with the help of Bodsy's brake bible for the Disco 3. The bang had knocked the shoes out of kilter somehow so I have re set up the parking brake from scratch and fitted new disks and pads at the same time...no more screeching or bongs or flashing warning lights.
Post #430805 11th Mar 2017 2:36pm
dolph34
Result !!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #430839 11th Mar 2017 7:33pm
