Home > Technical (L322) > Changed cluster now have warning lights on??? |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
I've just refitted mine after I had the LCD ribbons replaced. Mines did the same.. plugged in the iid tool and it was showing lots of bus related faults obviously to do with disconnection.. was able to clear them and nothing's come back.. |
11th Mar 2017 6:46pm |
S14WNO Member Since: 10 Mar 2017 Location: Lancs Posts: 24 |
When i refitted the origional clister the lights went off pretty much straight away after driving off... for some reason on the new cluster they are staying on... even the downhill mode light is very faintly lit. I have driven quite a distance today on the motorway, even left the car switched off for over an hour and they are still on. Its the annoyance of it, hate having lights on the dash |
11th Mar 2017 7:38pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
have you had the clocks coded ? I'm sure the clocks are coded to the car have PM'ed you also |
11th Mar 2017 8:48pm |
Iv not had them coded no, i assumed i could plug them in and they would work as normal. Replied to your pm mate |
11th Mar 2017 9:04pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
You only need to 'code' the cluster to your car to remove the tamper dot that appears next to the trip meter.
11th Mar 2017 9:44pm |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Everything said so far is true!
11th Mar 2017 10:48pm |
Thank you all for the replies. My mechanic has a top of the range snapon dignostics machine, would he be able to code it from that? I know some machines dont work resetting range rover susp etc but this one does. Hoping he will be able to code it from there... bloody range rovers! |
12th Mar 2017 10:54am |
Hi,
12th Mar 2017 11:48am |
I havnt no, how do i do this and what will it do for me? |
12th Mar 2017 12:09pm |
Start the car then turn the steering wheel fully left and hold it for a second then steer fully right and again hold it there for a second then steer to centralise. It sets the steering parameters.
12th Mar 2017 12:17pm |
