Home > In Car Electronics (L322) > Piggy back fuse issue |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
It wont be due to using a longer wire. Can you hold a length of wire on your earth point and the side of the lighter socket to check the validity of your earth point? |
12th Mar 2017 9:56am |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
I shall double check.. actually meant to post this in the l322 section oops! :lol:do you reckon it could be the earth point? |
12th Mar 2017 10:03am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
moved.. ... - .- -.
12th Mar 2017 10:09am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
Do you have a multimeter to check the connections? There is a convenient point to make an earth connection at the fuse box. Will have a look later where I put mine.
12th Mar 2017 10:11am |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
It will be something very simple. Are you sure the piggy back connector is plugged into a fuse socket providing power? Is the connector fully pushed home? Has the connector got a fuse in it? If you look at the blade fuse you wil see two tiny holes which just allow the tip of a multimeter to be put on to see if it's getting juice.
12th Mar 2017 10:14am |
@ Stan thankyou 👍..@ wee give that would be great if you could confirm the ground point..
12th Mar 2017 10:25am |
# weegie not wee give lol.. iPhone autocorrect at work |
12th Mar 2017 10:27am |
might typically be one of these, if so try the fuse in the other slot....
12th Mar 2017 10:43am |
^ +1 if plugging in to an unused fuse point. Otherwise two fuses.
12th Mar 2017 10:49am |
So based on Stan's pic (above) your dashcam fuse should be in the top (top/right) socket. The lower fuse socket homes whichever fuse (if any) you have taken out. 2006 4.2 SC
12th Mar 2017 11:44am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Buddy, you want fuse 7.. it's the empty one... comes on with the accessories..... and for your earth, I found a point that was under the cupholder (passenger popout) that was part of the steel frame that supports the dash and earthed there, the biggest problem with the ffrr is a lot of the screws that are self tappers, only go into a clip that is fixed on to a plastic part.. you really have to hunt to find a one that goes into real metal... but as I said there is real metal in the lower half of the dash around the cupholder Yesterday I couldn't spell Engineer... Today I are one!
12th Mar 2017 1:53pm |
Miggit your a star my man. Fuse 7 and a proper earth has done it I was earthing it to a screw that was painted and obviously one of the self tappers l.I now have power.. thanks to everyone who's contributed.. |
12th Mar 2017 2:30pm |
The problem with fuse 7 is that it is live in ignition 1 position so doesn't switch off when you stop the engine. That's why I went for fuse 1.
12th Mar 2017 3:17pm |
^ Why is that a problem?? Surely your never actually going to use it without the engine running, so as long as your not in the habit of leaving the key in the ignition when it's parked then it shouldn't be a issue Or have I missed something? Yesterday I couldn't spell Engineer... Today I are one!
12th Mar 2017 3:23pm |
