Home > Technical (L322) > Dead fuel gauge
Gumball3000
United Kingdom 2011 Range Rover Vogue SE TDV8 Zermatt Silver
Dead fuel gauge
Hi guys,
Just bought my first L322 td6 2004 RR , one of the first problems i have is the fuel gauge is pointing to below empty all the time.
But the weird thing it the yellow fuel light works and the range on the trip computer .
So i can assume the sender in the tank is working.
Thanks in advance.
Paul
Post #430871 11th Mar 2017 10:35pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I am lead to believe there are 2 fuel senders and the average the fuel level between them, I noticed that mine when completely full that thee Needle does not sit right up at the full mark.
Post #430924 12th Mar 2017 12:37pm
Mightymarcos
Mine suffered a whole different problem - if I had to restart the car with tank about 1/4 full, the gauge would sometimes be dead but after driving a while it would come back to life. Could this just be a bad spot on one sensor? Taking a rest from Land Rovers for a bit.......
Post #430972 12th Mar 2017 8:08pm
Gumball3000
Just done the cluster check sequence , no movement from the needle . All the other needles and gauges work including the low fuel light.
So is it a repairable part or a whole new instrument binnacle ?
Post #430977 12th Mar 2017 9:03pm
