Home > Technical (L322) > Towing electrics |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 336 |
If nothings working then i'd start with the earth connection as that is common to each light.
19th Mar 2017 6:49pm |
Possibly it's the trailer electrics rather than the car as it was working before. But if not then check the plugs as a starter for ten. Open them and check the wires are all good before you tackle the car. There is nothing that can't be fixed with a hammer😜😜
19th Mar 2017 8:15pm |
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 131 |
Corrosion of the ground wire/pin in the plug is the most likely cause. 2012 Westminster 4.4 TDV8 (sold)
19th Mar 2017 9:41pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
Have you checked at the plug with a multimeter ?
19th Mar 2017 10:19pm |
