Home > Technical (L322) > L322 tdv8 stored code P2071 but no MIL Light? |
pk7976 Member Since: 09 Mar 2017 Location: Kingston Upon Hull Posts: 33 |
Good morning am a new member and also new to the world of landrovers and rangerovers having just bought a 2007 tdv8. More out of curiosity I connected an Autologic Obd2 reader to the car and appear to have P2071 stored despite no warning light on the dash board. A quick google finds DTC Description: Intake Manifold Tuning (IMT) Valve Stuck Closed (Bank 1a) I have tried clearing the code but it does come back so before I start ripping the car to pieces blindly, does anyone have any experience of this or guidance on where to start fault finding testing in situ.
20th Mar 2017 8:07am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1692 |
Vacuum controlled actuators on each inlet manifold alter the length of the inlet tract
20th Mar 2017 11:00am |
20th Mar 2017 1:01pm |
THere are also another 2, one on each cam cover (inlet manifold is integral)
20th Mar 2017 2:55pm |
Had a look tonight and found a small pipe which was not connected but don't suspect this being connected to the main issue as its a small pipe that appears to connect to the back of the air filter housing? regardless its connected back to where I think it belongs. Am not really sure I have found the IMT valves on the inlet manifolds would be really helpful if anyone has a picture where to look? |
21st Mar 2017 12:36am |
Neither. They are seperate electronic controlled flaps in (what would be called) the throttle body, were the upper Intercooler hoses go onto |
21st Mar 2017 11:01am |
21st Mar 2017 11:04am |
Mikey that is brilliant, really appreciate your help! No wonder i could not find them they are buried at the back of the engine and not the front where I was looking.
21st Mar 2017 11:20am |
