Home > Off Topic > Any TV / Satellite engineers here?
mzplcg
As title chaps. What I want to know is whether satellite co-ax cable can be used on a free view aerial.
Like a dope when we built the extension I cabled it all for satellite but now SWMBO wants free view. Can I just replace the dish with an aerial and change the connectors at the TV end?
Thanks in advance
Post #431846 20th Mar 2017 10:19pm
not a tv engineer Dom but i've done loads of messing about with dishes and aerials and yes you can use sat coax as tv coax, if fact sat coax is slightly better screened so less signal loss on longer lengths.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #431848 20th Mar 2017 10:32pm
As Stan says, the cable is the same but better. The only difference is type of connector you put on the end of it. Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #431860 20th Mar 2017 11:46pm
Might me easier to buy a freesat box than put up an aerial ?
There are both freeview and freesat boxes available, they do basically the same thing, but with a different receiving device.
If your TV had built in freeview, then that may tip the balance for an aerial being the neater option though......
Post #431863 21st Mar 2017 2:01am
I have my free view aerial wired using satellite cable, never been a problem for the last 16 years.
Post #431868 21st Mar 2017 8:32am
+1 for the FREESAT box. It's just plug and play with your sky connections. Previously..
Post #431870 21st Mar 2017 9:34am
Mr Tee
If you ask nicely, I probably have a direct male to rf screw fitting from my days as a cable guy lying around somewhere.
Post #431875 21st Mar 2017 10:47am
mzplcg
LOL, pretty please, with cherry on top Mr. Green Mr. Green
Nice one Stan Thumbs Up
So, the TV in question actually has on board Freeview and a satellite decoder (not Freesat). It's the kitchen one which also goes with us in the caravan (Avtex 24" thing which will run on 12 volts)
The on board satellite is fairly rubbish, the planner never works and channels are limited depending on which satellite the dish is pointed at, normally Astra 2E. But the freeview is a lot better as we found out a couple of weeks back in the caravan.
Then we have 4 other TVs in the house, all Samsung. 2 have on board sat, all 4 have Freeview. So, I reckoned on replacing the satellite dish with a mahoosive aerial which can feed 5 tellys. Does that sound feasible?
Post #431877 21st Mar 2017 11:03am
Mr Tee
Yes, feasible. I used to wire up systems like that, using passive splitters. Do not use those cack y piece splitters, they were ok in the 1980's ! Your TVs will probably at different ends of the house , migyt be easier fitting 2 separate aerials.
Post #431911 21st Mar 2017 2:55pm
mzplcg
Yes, there is already an aerial on one end of the house which would do the 2 upstairs TVs and teh wiring could go through the loft without issue.
It's the downstairs ones where I can't run wiring without damaging the new plaster work, hence why I wanted to use satellite cable. And the dish is at the other end of the house although the pole would accommodate an aerial as well as the dish.
Passive splitters??? Would something like this be OK?
http://www.ebay.co.uk/itm/4-WAY-OUTDOOR-TV...1714125649
Post #431936 21st Mar 2017 5:18pm
Mr Tee
Lol, I might have spare 2 way one Cool
Post #431938 21st Mar 2017 5:31pm
the cable will all be fine, we use the same cable for sat and TV when wiring up new houses and it works well.
can you get the cable into the loft form the sat dish? the only reason I ask is if you have one aerial and its working well then the best cause of action would be to being all the tv feeds and the aerial feed to one point in the loft and add a freeview compatible amplifier, fed from the aerial distributing to all the individual TVs. Much better than splitting the cables.
If you have good signal you may get away with splitting it, but if you can get all the ends to the same place, and have a power feed to a light or something in you loft then youre golden.
if the cable form the sat is not long enough, you can link in another section by using the sat fplugs and a straight connector. There is nothing that can't be fixed with a hammer😜😜
Post #431942 21st Mar 2017 6:05pm
RR2008HSE
As others have said, sat cable is better, so can use for Freeview. You can't go the other way, though.
Post #432173 23rd Mar 2017 12:54am
