Home > Technical (L322) > Seat belt chime no chime and seat belt light goes out
Louismacrides
United Kingdom 2004 Range Rover Vogue SE 4.4 V8 Epsom Green
Hello all ,I have 2004 4.4 vogue the only thing that doesn't work is the seat belt not in use does not chime but light goes out ,this must ev been done by previous owner ,I looked at fuses and reset dash cluster ,I've checked connections under seats all seems normal ,how has this been done,I also done the fasten seatbelt 9 10 and 20 times tip ,I still think it cud be fuse ,any advice as I wud rather it did work as I have kids ,kind thanks
Post #432285 23rd Mar 2017 5:18pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi,
Mine doesn't chime when it's not in use or do you mean you want it to chime when it is in use but not buckled?
Because either way mine doesn't chime regardless.
Cheers ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #432299 23rd Mar 2017 6:26pm
Louismacrides
Hello when u say not in use can you turn it off . It never chimes no matter what on seat belts
Post #432320 23rd Mar 2017 7:43pm
Louismacrides
I've only had her 2 weeks
Post #432321 23rd Mar 2017 7:44pm
As standard they chime, it can be disabled, and is by many, and there is a post somewhere with how to do it, it is a plug/unplug the belt thing. Not sure if it's just the reverse to deactivate it tho.
Apparently it's either 9 or 10 times with ignition on within 30 secs.... There is nothing that can't be fixed with a hammer😜😜
Post #432323 23rd Mar 2017 7:44pm
Louismacrides
Hello I have tried this no luck and everything seems still plugged in but I will recheck
Post #432327 23rd Mar 2017 8:17pm
UK Marine
Mines never chimed when the seat is occupied but the seatbelt is unbuckled. I've had a look with my IIDTool and can't see the option to enable or disable a chime...... is this not just for the later models?? ______________________________
Simon
Post #432328 23rd Mar 2017 8:18pm
Louismacrides
That would explain it . If they just don't do that on 2004 models
Post #432331 23rd Mar 2017 8:35pm
That's a fair point, I wonder if the bong was for ford era cars. There is nothing that can't be fixed with a hammer😜😜
Post #432333 23rd Mar 2017 8:47pm
CS
My 2004 chimed if the seatbelt was not on. Only Range Rovers since 1988
Post #432338 23rd Mar 2017 9:19pm
Louismacrides
I will keep looking and reading . I notice fuse 37 was missing . Fitted it with no luck . Looked it up it says transfer box and towing operation
Post #432353 23rd Mar 2017 9:55pm
UK Marine
I'll have a go down the farm track tomorrow not wearing my seatbelt just to see if you need to be moving to activate the chime. Other than that mine might be faulty because it's never chimed all the time I've owned it... ______________________________
Simon
Post #432366 23rd Mar 2017 11:01pm
Louismacrides
Thank you
Post #432368 23rd Mar 2017 11:05pm
My 2012 chimes as soon as you move off if any occupied seat belt isn't buckled. I also looked with the IID tool to see if I could switch it off but haven't found where yet. Grateful for pointers if anyone knows please... Mike - MPx
Post #432387 24th Mar 2017 12:48am
Sit in car
Close door
Push ignition button without foot on brake
Put buckle into receiver 9 (maybe 10) times within 30 secs
On the final time you will hear a bong
Job done There is nothing that can't be fixed with a hammer😜😜
Post #432395 24th Mar 2017 8:35am
