Home > Technical (L322) > Strange air suspension issue????? |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
May be worthwhile checking and redoing the calibration on the EAS. when I replaced my front airbags last year I had weird issues with heights on each corner. Did a recalibration and all was well. Then when I replaced the compressor piston ring at Xmas, had the same troubles. Did another recalibration and not had any issues since.
22nd Mar 2017 8:25pm |
Covbandit Member Since: 11 Jan 2016 Location: Coventry Posts: 102 |
Always been a bit scared of doing a calibration in case l mess it up and end with a problem like my p38 where it used to sit and do a dance at the lights. Is it straight forward? Sounds very plausable that it could be the problem. |
23rd Mar 2017 12:34am |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
I'm sure you can save your current height/calibration settings in the iid tool pre adjustment and if you get it wrong you can reinstate the old settings and start again |
23rd Mar 2017 12:56am |
Thanks, l saw the save page so really got nothing to lose.gonna find somewhere nice and flat and give it a go. Never gave it a thought to calibrate the suspension. It could be fighting with itself and getting confused. |
23rd Mar 2017 9:25am |
It's best to use the EAS Calibration Guide that IID supplies in the manual, makes the whole job a lot easier. |
23rd Mar 2017 12:58pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
If you have the bluetooth IID tool, download the latest version of the APP, and the IID tool firmware.
23rd Mar 2017 7:00pm |
Wow..... just downloaded latest firmware and what an amazing bit of kit. 5 minutes at the most. Well thanks everyone for your help. Perfectly calibrated now and will see how the gremlins go now.
23rd Mar 2017 7:36pm |
2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
24th Mar 2017 4:08pm |
Ok still playing up. Will just drop down whenever it feels like it whilst driving or stationery, door open or shut and the inhibitor on or off. I have a feeling it is the valve block on the resevoir. According to rave this has 5 solenoids. 1 for each corner and one main one. So l think the solenoids are sticking/faulty. I sometimes lose both fronts but more often just the o/s. Today the hissing was really loud and was not letting the front come back up. Whilst engine and compressor running it hisses as soon as the ignition is cut it stops instantly, so l am sure it is something electrical controlling the air. Cant track the hissing down at the moment as l am a bloody raspberry ripple l cant get in to listen. So l have tracked a valve down and will get someone to poke their head in to track down the hissing.either way no matter what l have to change l wont be scared of calibrating next time. Has anybody else had any issues with the valve block on the resevoir?
24th Mar 2017 10:00pm |
Ok hopefully this is the final update. Changed valve block and she ran perfect....... for 1 day then problem returned. Decided that although airbags had been changed l would need to start again. Removed o/s wheel increased air into bag using the iid tool, squirted good old soapy around the bag and it is leaking. The bottom seals where it meets the strut. So removed bag cleaned everything up- reseated with rubber lube and it has been perfect since. Stays up over night, not dropping whilst driving and compressor kicking in a lot less. So fingers crossed sorted and just goes to show even a new part can still be faulty.
31st Mar 2017 1:13pm |
