Home > Technical (L322) > Supercharger Coolant Pump |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 423 |
I've just had a quick investigation into the boot fusebox to see if there was anything untoward happening.
1st Apr 2017 11:06am |
unsolicited Member Since: 30 May 2016 Location: London Posts: 123 |
The pump works all the time the ignition is on. You can hear it clearly if you get to the front nearside (near the headlight) with the ignition on.
1st Apr 2017 8:09pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
The pump is on demand and should not run all the time . 2008 MY Supercharged
2nd Apr 2017 2:14am |
According to the workshop manual it should run when the ignition switch is in position II
2nd Apr 2017 8:23am |
I think you have the answer there , it must prime itself on start up . 2008 MY Supercharged
2nd Apr 2017 1:01pm |
A little more investigation has revealed that Fuse 7 (15 amp) is indeed for the Aux Coolant pump. It appears that the vehicle handbook is full of crap and my indy found the correct diagram for the rear fusebox.
3rd Apr 2017 2:03pm |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 |
I was looking at mine yesterday , and can Tell you the plug for the aux pump breaks out of a loom that carries on elsewhere .
22nd Apr 2017 7:33pm |
Thanks Ian.
23rd Apr 2017 6:44am |
It's easy enough to check yourself .
23rd Apr 2017 4:29pm |
Just to conclude, it was at my indy yesterday.
6th Oct 2017 8:01am |
Did they also check to see if it’s wired correctly ? |
10th Oct 2017 5:22pm |
Ian, they'd already made the wiring correct when they first fitted the new pump. Still running fine so all is well. 2017 5.0 Autobiography Supercharged
10th Oct 2017 6:07pm |
That’s great .
10th Oct 2017 6:12pm |
strongstuff Member Since: 26 Jun 2019 Location: North Wales Posts: 44 |
A little thread resurrection
31st May 2021 12:57pm |
