Home > Maintenance & Mods (L322) > trust me only i could do it |
HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169 |
aftersome reading up on my problem i belive it to be INJECTOR T PIECE LEAK OFF CONNECTOR and the fuel pipe where it joins it ,now is it an easy swap for a new T piece?or has the whole injector need replacing thats the last time i service the car nyself |
22nd Apr 2017 9:20pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
These T pieces and leak off pipe lengths are easy enough to find on eBay, and it maybe that Europarts or similar may hold stock of them if urgent. The T pieces get quite brittle after a few years, and the O rings can disintegrate, it may be worth having a few spare, just in case more break during the repair as separating the pipe from the T piece can be a sod too.
22nd Apr 2017 11:45pm |
Thank you Joe very helpful don't suppose you know what diameter fuel hose pipe she needs? |
23rd Apr 2017 7:55am |
Not sure, without going out and measuring, but the Bosch common rail injector pipe is the one.
23rd Apr 2017 11:16am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
When I was doing the injectors on my Mercedes I noticed the the plastic 'T's' were looking well past there sell by so I replaced them with a brass set... they are the same as the ffrr returns, so this will work fine with your engine http://www.ebay.co.uk/itm/Leak-Off-Connect...SwBPNXSFmC Yesterday I couldn't spell Engineer... Today I are one!
23rd Apr 2017 11:48pm |
thank you all very helpful just have to change them now |
24th Apr 2017 6:05pm |
Easy to do, however I would recommend that you use a set of pin nose pliers to remove the clip as they have a nasty habit of pinging off in to the distance when a screwdriver is used!! Yesterday I couldn't spell Engineer... Today I are one!
24th Apr 2017 7:35pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
That's why they are called Jesus clips
25th Apr 2017 2:08pm |
