Home > Maintenance & Mods (L322) > Windscreen shattered! |
Foulolron Member Since: 05 Aug 2015 Location: East Yorkshire Posts: 29 |
Think most (if not all) national windscreen replacement services are mobile - had mine replaced last year (via Admiral use autoglass), asked I'd I could call I to depot to get it fitted to be told they don't do fitting there any more |
24th Apr 2017 6:23pm |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
Make sure it is a LR genuine replacement Regards
24th Apr 2017 6:39pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 468 |
I've just had mine replaced using Auto Wndscreens. Really good job, Pilkington screen without me telling them to do so. It's just a shame that after 2 hours the fitter was doing the final bit (refitting the rear view mirror) when he found he'd fitted the wrong screen. Apparently the BMW connector for auto-lights and wipers is different to the later one!
24th Apr 2017 6:45pm |
Don't think you can insist on genuine LR screen (unless you pay extra for it)- I asked and was told it will be the same as - only difference I found it didn't have the LR logo had all the same part numbers it was graduated at the top, acoustic etc and was fitted fine - no leaks |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7762 |
I specified Pilkington with Auto Glass - they agreed straight away, just told me it might be a few extra days to source one - turned out that they had one locally and was fitted within a few days - they could have fitted it sooner than I was available.
24th Apr 2017 7:54pm |
We insisted for our freelander 2, and autoglass collected it from the dealer........ Regards Royston 2008 4.2 Supercharged Autobiography 1994 Classic Vogue SE 1999 Rover BRM 1987 Rover Vitesse Twin Plenum |
24th Apr 2017 8:20pm |
No real difference between Pilkington and LR
24th Apr 2017 8:40pm |
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 |
Thanks for replies , as stated it is cracked not shattered, looks like I'm going have wait till get home before getting it fixed, do I need tell insurance first or just get it fixed and let windscreen company sort out paperwork ? Will make sure it's right screen before letting fitter touch it, I'm back home on Friday in Lincolnshire till then. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
When my screen needed to be replaced I called the insurance co to ask what the procedure was, they said to contact Autoglass, their repairer, and take it from there. That was in the days when they still had their own premises and I went there to have the work done. Now I think they come to you. They used a Pilkington screen and everything worked as it should afterwards. If your insurance policy says you can just contact the windscreen company that should be OK, but you can't go wrong checking with the insurers first. Only Range Rovers since 1988 |
24th Apr 2017 9:08pm |
Had a look online at Admiral's website it directs to Autoglass and allows you to book appointment and pay excess , so it's due to be fixed on Sat morning at home, put in message box I expect Pilkinton replacement as is fitted, lets hope it all goes well. I'll need buy another FFRR sticker now!
24th Apr 2017 10:16pm |
Autoglass made a decent Job of mine. And they seem to know the score. I would call and check that they are getting you what you have asked for into stock.
25th Apr 2017 4:16pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2215 |
I have had two from auto glass last one they did a great job as said before they will use pilkington which is same as LR without the logo just make sure they have the trim pack as well which replaces the top trim also they need two fitters to do the job properly |
25th Apr 2017 8:08pm |
Been apprehensive all week waiting for today, need not have worried, Autoglass turned up after text narrowing it down to 2 hr window. (15 mins into it) one technician first, he rang 2nd guy to confirm Pilkington glass 👍. He then started removing trims etc ( side trim clips broke as expected, but said 2nd guy had replacements) 2nd technician arrived with screen etc and they got on with it, took opportunity clean scuttle trim whilst it was off, screen in, new side trims unwrapped not just clips.
29th Apr 2017 8:04pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
Sounds like a very good result...... 2017 4.4 SDV8 Autobiography
29th Apr 2017 9:09pm |
