Home > Maintenance & Mods (L322) > Cam cover gasket sealant |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
You only need it on the two half moons and a bit either side and a bit over and either side of where the front timing covers join, I have got the loctite number somewhere if you need it.
28th Apr 2017 12:27am |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Thanks mate.. I've got the loctite you linked on a post a while back 👍 |
28th Apr 2017 6:13am |
No bother, i have attached the page from Rave manual, you must get yourself a copy if you don't have one already, but it probably wouldn't do any harm putting sealant all round but messy and i have never done it and mine are sealing fine.
28th Apr 2017 8:45am |
Job done thanks for the heads up.. drivers side done my head in as everytime I had just about got it seated the gasket would fall out. Added more sealant then tried again. Nope! Five try before I finally got it lol..got dark before I could fit coil packs ect so hopefully there's no leaks.. |
28th Apr 2017 8:52pm |
. Dropped one of the special nuts that feeds into the washer then the rubber seal, there's 8 per side.. I cannot for the life of me find a part number.. any idea? |
28th Apr 2017 9:50pm |
Good work mate, it gets easier the more you do it, i think it took me 35 minutes to do my passenger side last weekend, but then i have done it a few times, there is a trick to removing the injector loom, which is get a hold of it either end and a sharp tug and it pops off.
29th Apr 2017 12:18am |
It must be the first one. The second ones the front 3 that you can't take the rubber seal off? The first pic must have the washer and seal with it in the pic as the bolt looks a wee bit different. Appreciate that buddy yeah the sealant underneath the half mooned area helped and next time I'm definitely removing the injector loom boxes. Would have been a lot easier.. just need to get the bolts from landrover today and the fattys back on the road.!cheers again |
29th Apr 2017 8:55am |
No worries mate, the seals do come off, you really need to replace all of them as well ideally
29th Apr 2017 10:00am |
I have those other 6 seals handy so will get them back off today and renew and jobs a good one |
29th Apr 2017 10:22am |
If the old ones wont come off then just cut them without removing your fingers and if the new ones are a bit stiff then put them in some hot water and they will pop over.
29th Apr 2017 4:57pm |
Got them off. Cars running and No leaks so I'm delighted. Thanks again
29th Apr 2017 8:10pm |
Actually did have 1 issue. Exhaust started doing this puff puff thing. Got that horrible sinking feeling as car sounded a bit rough.. just clicked I've not reattached the 2 vacuum lines to the throttle body air intake . Haven't had the chance to check as I'm away to work so hoping thats all it is |
29th Apr 2017 9:04pm |
As long as the nut you lost isn't in there you will be fine, the engine certainly won't be happy with a vacuum leak and as long as all your coil packs are back on there isn't a lot you can do wrong.
29th Apr 2017 10:36pm |
Found the nut. Torch and a long reach stick with a magnetic tip. Also found my missing 10 and 11mm sockets it was those vacuum lines, couldn't rest so went out and fitted them,
29th Apr 2017 10:45pm |
