Home > Technical (L322) > REAR HUB AND SPEED SENSOR PICK UP HELP NEEDED |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
There should be a reluctor ring. Mine rusted through and I had to buy a new drive shaft. I then found out that one from an X5 should fit. Think you can get them on eBay or the like.....if that's what you find it is. The speedo is fed from the rear left wheel, as you prob know.
30th Apr 2017 11:38am |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
Thanks, now I know where the reluctor ring must be, I will swap the sensor again to see if the new sensor is not the problem before I start the major strip down. |
30th Apr 2017 2:38pm |
update, the rear speed error is being caused by wrong sensor supplied, it should be SSF000021 and was supplied SSF500021 which is the from 06 models. |
1st May 2017 12:01am |
update, the rear speed error is being caused by wrong sensor supplied, should be SSF000021 and was supplied SSF500021 which is the from 06 models. |
1st May 2017 12:05am |
