Home > Technical (L322) > Roof Bars
n1cktdv8
Roof Bars
Do LR, Thule or similar sell a pair of cross bars that bolt directly on the roof mounts or do I need the front to back bars? Is this where I put the car details and a bit about myself ?........
Post #436802 2nd May 2017 8:52pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Yes, LR do "Sports Bars" that fit directly to the fixing points under the flaps in the top finishing 'rail' and they fix without needing the flaps removed.
VUB502790 about half way down the page http://duckworthparts.co.uk/landrover/acce...rying.html
Post #436806 2nd May 2017 8:56pm
n1cktdv8
Spot on thanks Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #436815 2nd May 2017 9:27pm
The Thule ones have a 'foot pack' which sits on the roof & has a thin piece which claps under the door aperture.
There a pro's 7 cons - the Thule bars are as wide as the car, whereas the LR ones are around 2/3 the width of the roof.....
Post #436822 2nd May 2017 9:51pm
n1cktdv8
It's just for 2 bikes, still toying with idea to be fair. Like Thule stuff but would prefer LR. Is this where I put the car details and a bit about myself ?........
Post #436823 2nd May 2017 9:55pm
I had Thule - but I had 4 bikes - the Thule bike racks lock onto the bars & the feet lock onto the car so all good Thumbs Up
I think the LR bars are wider, so would need some trimming for a Thule or other bike rack - could be wrong though....
Post #436828 2nd May 2017 10:04pm
proser
I have a set or LR ones in the garage if you want to try them before forking out for a set Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #436849 2nd May 2017 11:29pm
p38arover
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Rhino Racks also do them. I used the feet off some L322 Rhino bars to fit a Rhino Pioneer Platform o mine (even though Rhino say they don't make a kit to fit a platform).
See part way through this thread: http://www.fullfatrr.com/forum/topic32187.html Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #436851 2nd May 2017 11:46pm
Sandyt
I bought these and they have been very good indeed and are silent http://www.whispbar.eu/en_eu/select-vehicle/
Post #436857 3rd May 2017 5:46am
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
^+1 for the Whispbars, very quiet Thumbs Up
Post #436863 3rd May 2017 7:15am
n1cktdv8
Thanks. Have you carried bikes on the roof. If yes; if I mount the bars on the rear and centre mounts does the tailgate catch on the bike racks?
Post #436872 3rd May 2017 8:59am
proser
Sorry - haven't had bikes on there Regards
Mark
2012 Westminster
Post #436877 3rd May 2017 9:43am
Alfasprint88
New Zealand 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I've had the LR bars but then went to the rhino rack. I've got to say the rhino rack is a much better system.
Post #436885 3rd May 2017 11:33am
n1cktdv8
With regards the rear mounting points; do the bars bolt to these OK or just to the middle and front. I only ask as the roof aerial seems too tall and would obstruct the bars?
Like this;
Post #437358 7th May 2017 5:11pm
Giantlandyman
If I remember correctly, there was a guy on here who sold three bars and pictured his car with all three in place a while back.
I believe the idea is that the front and middle are used so as not to impeded with the upper tailgate rather than the aerial being in the way.... the middle and rear could be used if that suits.
I think there is a reason why they can't be spaced or placed front and rear...... I believe the middle one (of the genuine LR) can only go in the middle being slightly wider than the front and back.
To have a front and rear would require an additional front from another set which is what this guy did.
Post #437383 7th May 2017 7:26pm
