Home > Technical (L322) > Deployable side steps |
Jpickie Member Since: 02 Nov 2011 Location: Oxfordshire Posts: 44 |
On mine there is only one fuse for the whole system, its the first of the large fuses, F61 30A green fuse on the far right of the fuse box behind the glove compartment. MY2007 S/C - Stornoway / Jet |
15th Dec 2011 4:58pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
Decided since it was a nice day for a change that I'd have a go at fitting my deplorable steps today
29th Dec 2016 9:10pm |
Since my CCF nightmare, I've been slowly getting back to normal and 1 thing I've found is that my steps are no longer deploying. The IIDTool sees the RDM ECU, which controls them and looking at the live values, it can see me opening and closing the doors, but no step deployment.
7th May 2017 4:18pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
do they work on the roof switch... ... - .- -.
7th May 2017 4:27pm |
No Stan, they don't Got - 2017 SDV8 Autobiography in Loire Blue
7th May 2017 7:08pm |
do a battery reset alan, first little steps.. ... - .- -.
7th May 2017 7:45pm |
Already done that Stan Got - 2017 SDV8 Autobiography in Loire Blue
7th May 2017 8:01pm |
7th May 2017 8:09pm |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
Have you gone through the process as part of the install to initialise the ECM ??
8th May 2017 9:10am |
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 |
When connecting the steps for the first time, they need to be put in access mode. You need to keep the DSS button held WHILE you turn the ignition as pictured above. Press the button first and then turn ignition, this should liven them up. Jordan
8th May 2017 10:09am |
Fantastic gents! That sorted it!
8th May 2017 10:29am |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 201 |
Anyone got the 'user manual' for these rather than the install manual as I understand you can lock them open or closed but couldn't see anything on how to do that in the manual and someone suggested that there was an additional amendment of that but can't find it on Topix?
8th May 2017 12:27pm |
this any good ian,
8th May 2017 3:54pm |
Thanks Stan.
8th May 2017 5:28pm |
