Home > In Car Electronics (L322) > Electrics not going well
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Ok , got myself in a knot here, I have ordered and rescued a switch module fro Bimmernav to connect my reverse camera to the tv module. It's not good , I have searched the forum and links to get a clear view of what I need to do . I will try an explain. Rolling Eyes
So A is the lead supplied by Bimmernav which has a red and black for some pin numbers I guess for TV Module , blue or white
B Large dark blue ready for another pin number.
C conjoined yellow and red , ...could be earth on ring tab.
D I think is to reverse lighting wire
E & F comes from the camera , (12v live continuous)
G is red tail also from camera ?
H finally goes to I I presume .
I'm sorry I think I have seen this better explained , but cant seem to find it . Its not hard , but I ve lost the plot !
pat
Post #437753 9th May 2017 9:01pm
Freddie The Fish
United Kingdom 2011 Range Rover SE 4.4 V8 Fuji White
Have you got the manual up the right way ? Rolling with laughter
Post #437755 9th May 2017 9:03pm
Laughing ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #437759 9th May 2017 9:12pm
alfapat
Well well no help that
Post #437779 9th May 2017 10:47pm
Freddie The Fish
The comedy value has been lost now the pictures have been edited..., Stan was on my wavelength
Post #437804 10th May 2017 6:24am
alfapat
Thanks for that Rolling with laughter
Not the answer I was expecting. Neutral
Post #437806 10th May 2017 7:09am
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
this isn't a hard fix
cable A is for video IN
cable B is the trigger to the TV unit this needs to be a negative feed
cable B is attached to a relay looks like red and yellow cable C are attached together, this may be 12v live (feed from reverse camera) but could be 12v neg
guessing cable D is a neutral or 12v pos for the relay system
H and I connect together the other end of H would connect to the camera, the red wire running down the side of H is a power wire, you would connect this to the reverse live
cable E will be 12v reverse live, cable F negative for camera
if you can take better photos of the relay, and the holder and the wiring positions I can confirm further
I'm guessing it's a 5 pin relay with a typically open circut that is then switch into a 12v neg that the tv unit needs to see to switch on the camera input
Post #438219 12th May 2017 9:26pm
alfapat
Ok thank you very much for your reply, I have worked out the description you sent and tomorrow I will confirm this .
Post #438222 12th May 2017 11:07pm
