Home > Technical (L405) > Stealth mode |
Caddyshack Member Since: 03 May 2017 Location: Guildford Posts: 61 |
I believe it dims the "mood lighting" so it doesn't look like you are sitting in the car with the lights on...
11th May 2017 2:12pm |
AMTony Member Since: 01 Mar 2017 Location: North West Posts: 81 |
Car is fairly dark inside at night so only conclusion must be that mine doesn't work?
11th May 2017 2:29pm |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 |
On my car the Stealth is activated when you turn off the main screen. At that point the speedometer graphics go to the 'torchlight' mode, the temperature readouts turn off and mood lighting is turned off.
11th May 2017 2:39pm |
Thanks Nick - read something about this but how do you turn the screen off? |
11th May 2017 2:49pm |
Depending on your spec, there is a power 'hard' button on the bottom left side next to the screen, or it is a 'soft' button om the bottom left of the touchscreen home screen.
11th May 2017 2:51pm |
Thanks - will press and see what happens |
11th May 2017 2:55pm |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 |
Yep, you enable stealth, then read the instructions on the screen! Press the off button on the bottom left corner of screen 2010 defender utility
11th May 2017 10:08pm |
Thanks everyone - never realised there was the image of an on/off button on the screen.
12th May 2017 7:07am |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
what do people think of the overall intensity of the mood lighting, I have mine turned up fully but unless there is something like a cleaning rag in the door cubby reflecting the lights then I can hardly tell its on. this may of course be something I am not doing correctly. :-} Agueroooooooooo. 93-20
12th May 2017 10:11am |
w8pmc Member Since: 30 Oct 2016 Location: West Lancashire Posts: 229 |
Mine's set to blue & i'd say they're quite bright & certainly unmissable. Obviously in the daylight they're not as easy to see, but in the dark they're very obvious. Paul
14th May 2017 8:01pm |
Lutonboy Member Since: 26 Dec 2016 Location: Bedfordshire Posts: 35 |
I've set mine to orange/yellow and its fairly unassuming even at full brightness. I like it though, fits well with the Almond/Espresso. |
16th May 2017 2:52pm |
