Home > Technical (L322) > Parking sensors! |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
Could be the Bcu - this is just one of the functions it controls. My pdc set off the "not working" alarm sound on start up but work fine 2 mins down the road. New bcu required! |
25th May 2017 10:57pm |
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 |
Bcu?...? |
26th May 2017 12:49am |
Body control unit -it's under the passenger seat. If you change it you will need to get the new one re-coded to your car (main stealer job?)
26th May 2017 7:15am |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 452 |
Replacing my BCU - to cure intermittent rear door unlocking and heavy steering problems - also cured an intermittent problem with my rear parking sensors which I had not associated with the BCU.
26th May 2017 9:52am |
Put the CTec on for a bit and thought I'd do a disconnect on the battery while I was there ( it used to cure things on the BMW 750i) and lo and behold the PDC has started working again, let's hope it stays working 😀 |
27th May 2017 10:32pm |
