Home > Technical (L322) > Very Weird Problem help !!!!!!!!!!!!
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi Guys
Had a weird one start today, was driving along then got the HDC inactive message, stopped restarted no issues and carried on.
Went to the petrol station filled up restarted loads of issues HDC, transmission, headlights steering etc.
Read my codes with GAP tool, cleared and drove fine.
Now ever time I start it I get a transmission error and the following codes on the GAP tool. Clear the codes and car drives fine.
I have checked the battery as its new 14.2 volts running and 12.4 when engine is off so looks like battery is good.
Once codes cleared the car drives as normal, also does not start first time does nothing like if you try and start in drive, then try again and it will.
Any ideas its a weird one.
Thanks
Post #441664 16th Jun 2017 9:36am
lighthouse
Now it's dead in a car park not second stage ignition no dash rights no ac nothing on second stage anybidwas
Post #441685 16th Jun 2017 1:28pm
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
I had issues very similar to what you are experiencing a week ago with my 2006 Vogue. Turns out the battery was failing. I changed the battery with a new one from Halfords and everything worked OK again.
I had the alternator checked out yesterday, and it is pushing 14.4 volts, so that is working OK.
Sounds like your battery is not holding a charge to me. Try putting it on a trickle charger for a couple of hours, then see if it starts OK. If so, get new battery soonest.
Post #441686 16th Jun 2017 2:01pm
lighthouse
The battery is only a month old.
Now getting no second stage ignitions at all.
Post #441687 16th Jun 2017 2:02pm
Sounds like you've been unlucky that your new battery has failed. Did Halfrauds supply and fit? What type of battery did they sell you? Got - 2017 SDV8 Autobiography in Loire Blue
Post #441697 16th Jun 2017 5:47pm
lighthouse
Now dead dead won't start on the back of a recovery truck. No second stage ignition at all.
Post #441699 16th Jun 2017 5:49pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
any update ?
Post #442341 22nd Jun 2017 8:31pm
lighthouse
Yes all fixed now had to put it into landcover, it was the key module had failed and lots of the coms between modules go via this module. Hence everything stop working.
Post #442361 22nd Jun 2017 10:51pm
Rich_Allen
This sounds like it could be happening to mine!
Was the key module expensive? Part of ignition switch?
Cheers 2008 TDV8 Vogue SE
2002 TD6 Vogue
2002 Defender 90 TD5
2002 Range Rover P38 Autobiography
2002 Range Rover P38 Westminster
Just a sucker for big bills!!!
Post #500453 3rd Jan 2019 8:01pm
