Home > Technical (L322) > L322 stuck tow bar. |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Hi
18th Jun 2017 5:59pm |
pip1977 Member Since: 13 Jul 2015 Location: Northants Posts: 16 |
A good soaking in release spray sorted mine out, had been in there for about 6 years when I got car. 2004 td6 Zambezi silver
18th Jun 2017 7:27pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
Assuming you have got the bolt out it is just a case of hitting it with a heavy hammer, they tend to be fitted dry and then bond to the armature with rust. Clean and grease the stem before refitting, it makes removal much easier next time. Only Range Rovers since 1988 |
18th Jun 2017 7:32pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
I never understand why people leave removable tow bars fitted when there is a space in the boot for them!.. Current: TDV8 (3.6) RRS HSE
18th Jun 2017 8:38pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
....probably cos they are stuck. ... - .- -.
18th Jun 2017 8:41pm |
phillips321 Member Since: 05 Nov 2016 Location: Countryside Posts: 50 |
Just applied lots of WD40 in the hope this loosens it up.... here's to hoping. |
19th Jun 2017 8:36am |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
I would try penetrating oil rather than WD40... |
19th Jun 2017 9:12am |
Apologies but my knowledge of this i guess is a bit thin on the ground.... I thought WD40 was penetrating oil? I have GT85 as well? Or a lots of firearm gun oil like this stuff http://www.uttings.co.uk/p103759-bisley-silicone-gun-oil/ |
19th Jun 2017 9:15am |
You need the oil to be mixed with a release agent, more a penetrating action.
19th Jun 2017 9:33am |
The clue is in the name - WD stands for Water Dispersant. You need something like Plusgas |
19th Jun 2017 9:50am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
+1 for PlusGas 2017 4.4 SDV8 Autobiography
19th Jun 2017 6:44pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3678 |
A small container full of diesel is good to use for penetrating oil in such cases.
19th Jun 2017 7:08pm |
@stan.. Current: TDV8 (3.6) RRS HSE
19th Jun 2017 7:14pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3646 |
Mine was stuck when I got it, soaked in penetrating oil battered with a sledge hammer - still wouldn't budge - so I just cut the bottom off and left it there. Geoff |
20th Jun 2017 5:28pm |
