Home > Maintenance & Mods (L322) > Jumpleads |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
Anyone know of a reputable set and where to buy them? I used to have a great set years ago when I was a Truck engineer but they were always ordered in for us from some supplier.
2nd Jan 2011 9:07pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
machine mart have some pro ones for £35'ish... ... - .- -.
2nd Jan 2011 9:15pm |
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 |
Noddy,
2nd Jan 2011 9:28pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
These should do:
2nd Jan 2011 9:35pm |
Nigel,
2nd Jan 2011 9:45pm |
2nd Jan 2011 9:56pm |
Doh, just picked link for 1st 1 , so here are the others. Make your own mind up.
2nd Jan 2011 10:02pm |
difficult to decide between the two nigel.... ... - .- -.
2nd Jan 2011 10:56pm |
I have some similar to the ones Mick posted. Great quality but very cumbersome to lug around, the weight of them wants to pull them off the terminals too. I paid about £20 from a motofactors I think. |
3rd Jan 2011 12:11am |
That was exactly what I did when I was a mobile service engineer. I had a heavy duty set which I cut near to the one end. I fitted Anderson plugs inline and made up some short leads which I attached to the vans battery. I then cut out a small section of the radiator grille for the other Anderson plug. That was a great little set up as I could arrive on site to a flat battery and jump start it with very little effort. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
3rd Jan 2011 2:03am |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
truckstop in worcester on blackpole est sell HD jumpleads for trucks there only about £20 ish they make them themselves have a look on your travels onto no6 Range Rover
3rd Jan 2011 5:19pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
Well all that energy going up in heat is energy that isn't making it to the battery which will make all the difference on a FFRR. I have a home made set with leads so heavy they bend the clips. Really must get some new clips for them. 2010 Disco XS TDV6, 2009 Freelander 2 GS Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy". |
3rd Jan 2011 7:26pm |
Sorry for being pedantic but its more important to consider the car you are jumping. A starter motor which is having to do a lot of work will try and draw as much current as possible through the leads from the donor car and thats what will overload them... Cheap, too small leads can easily get too hot to touch, melt the insulation and then short out the battery - Not funny. If you are in a bind and only have cheap, light duty leads to hand, there is a good chance you will give them a go because "whats the worst that can happen....?" I investigated an incident a couple of years ago where a qualified mechanic had tried to start a big engine that had one faulty battery on its 24v system and after numerous attempt he realised the problem and jumped the faulty battery with a good one. Electrically, it was an okay thing to do but a spark ignited the expelled hydrogen gas from the exhausted battery which blew the top off the battery and sprayed hot acid everywhere... |
3rd Jan 2011 11:05pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
Well i'm happy with my cheap pair that i have, they did not get hot and there was no explosions.
3rd Jan 2011 11:39pm |
