Home > Maintenance & Mods (L322) > Advice on fitting brake pads
Webbie
I fitted new disks and pads to my MY2011 TDV8 a few months ago and did not grease the back of the pads, as they had the self adhesive high density foam pads on the back. I now have deep tone break squeal with low speed braking.
Should I have copper greased the back of the pads even though they have the anti-squeal backing?
...and should they simply be greased now?
Post #442093 20th Jun 2017 2:17pm
nino_nino
are those original disks and pads or aftermarket?
Post #442109 20th Jun 2017 4:32pm
Webbie
Genuine Land Rover from Dan at Duckworths
Post #442110 20th Jun 2017 4:43pm
nino_nino
you may wanna try "cleaning" the disks while driving (advisories - nice deserted pace of road etc...etc..)
bring car to 70-75 mph then apply brakes, pressing light at first then increasing pressure till you are at 30-35 mph, accelerate and do the same thing 3-4 times.
Hope it helps.
Post #442119 20th Jun 2017 5:15pm
Webbie
will give it a try in the morning. better than striping them all down again.
Post #442121 20th Jun 2017 5:33pm
Webbie
Tried the hard breaking idea, no better. The problems now getting worse, with vibration being felt inside the car.
Should any ideas anyone?
Post #442631 25th Jun 2017 8:52am
Weegie
Sounds more like a sticking caliper if you are getting vibration. Check the slide pins and re grease them. Alternatively, is there a warped disc? Unlikely as they are new but..
PS. After driving check the wheels for temperature. If one is hotter than the others then start with that. John
GAP iiD BT
Post #442632 25th Jun 2017 9:00am
Webbie
Thanks, will give that a try this, I had not thought to grease the pins. While everything in apart, should the back of the pads be greased or left dry?
Post #442652 25th Jun 2017 11:32am
Weegie
I would put a very light smear on the back. John
GAP iiD BT
Post #442657 25th Jun 2017 1:00pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
use a white lithium grease
Post #442658 25th Jun 2017 1:35pm
nino_nino
where is vibration coming from? front, rear, left, right. is it always present or only under hard braking? if you trailing the brakes do you feel pulsation on the pedal?
Post #442665 25th Jun 2017 2:25pm
Webbie
The vibration is coming from the front near side. It only happens at very slow speed, like a couple of miles per hour, with very very light touching of the break peddle. Firm pressure to the peddle gives no squeal or vibration. Typically occurs when slowing the car in slow rolling traffic. No binding on the breaks at all. Car stops well and otherwise everything is in order.
Post #442670 25th Jun 2017 5:28pm
nino_nino
No need to grease the pins on the front calipers, it is rear caliper that have sliding pins which require greasing.
looks like your front discs are warped or you have not cleaned the mating surfaces( disk hub and half shaft) when installing disks.
what shape are the old disks in. is there enough "meat" on them to be machined? I believe that min. thickness is 31mm.
if you go to the masinist ask them to machine inside the disk hub to(just the fraction of the mm) so that all surfaces are parallel.
Post #442678 25th Jun 2017 7:47pm
Webbie
Thanks again for the reply, the old disks we totally shot and have been skipped. The new ones were true when that were fitted, but I just bolted the new disks on without cleaning the mating surfaces, so I guess that could well be the problem.
Post #442694 25th Jun 2017 9:31pm
stu
It's not unheard of to have warped new discs! I had a set when I did the discs on my 3.6. Pain in the ass finding out they are damaged and having to by and fit a new set before returning the warped ones..
Love these cars... Thumbs Up Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #442797 26th Jun 2017 6:56pm
