Home > Maintenance & Mods (L322) > Battery Replacement 2011 TDV8 4.4 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3680 |
Excellent step by step guide. Thanks 👍👍 G reg 2.5VM Vogue Portofino red 1991- 1999
6th Jul 2017 7:15pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
6th Jul 2017 7:49pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Thanks for pic. scuddriver. have tool, battery and the pictures. ready to go
6th Jul 2017 8:16pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
Cracking write up. Can we add this to the Wiki Stan?
6th Jul 2017 8:41pm |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 144 |
What is this battery disconnect device?Can't one just disconnect the battery starting with the neg.?If this car needs a battery far away from the stealers can you just replace?I have the special 5 point Torx tool to remove the ECU's Only have the iCarsoft tool,planning to get the GAP tool.Can you replace the battery without telling the car it has a new battery...what will happen if you don't tell it? 2012 TDV8 Vogue SE 4.4 |
6th Jul 2017 8:44pm |
I understand the battery disconnect device automatically disconnects the battery if the car thinks it's been in an accident. It's not a device/tool that you need to buy to disconnect the battery. Does it use a small explosive to fire the connector off the battery in a crash?
6th Jul 2017 9:09pm |
From the Workshop Manual....
6th Jul 2017 9:19pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
It is not fitted to my MY12. |
6th Jul 2017 9:22pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
great write up, put in the wiki.... ... - .- -.
6th Jul 2017 9:25pm |
Thanks Graeme. Good to know. ______________________________
7th Jul 2017 3:43am |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
Great write up
8th Apr 2019 7:38am |
I changed my battery back in July last year but did not reset the car even though I have an iid.
8th Apr 2019 8:50am |
Also, I found that I did not need to unplug the multi connector on the control unit, because like Nino I had removed the air box, their was sufficient slack in the harness to simply move it to the side and lift the old battery out.
8th Apr 2019 8:57am |
Thanks Baltic blue. Regards
8th Apr 2019 10:12am |
