Home > Technical (L322) > 4.4 TDV8 Suspected electrical issue |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2307 |
#1 is what mine did when the battery was failing and unable to hold proper charge. If the battery is original then maybe time for a new one. |
24th Jul 2017 1:00pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
I've had the starter just give a click now and again, but start no problem most of the time.
24th Jul 2017 6:40pm |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 167 |
I have just put a multimeter on the battery. 12.09v before it was started (it did a 100 mile run yesterday), 14.45v when running and then back down to 12.18v very quickly after stopping it again.
24th Jul 2017 8:15pm |
I very recently fitted a Varta G14 Start/stop AGM. It gets back to a float charge very quickly which is great for short runs. |
24th Jul 2017 9:40pm |
Looking at the battery fitted to it now it is a Land Rover part but is actually a Varta G14
25th Jul 2017 11:51am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
it appears that bms has to be reset Sam,
25th Jul 2017 12:43pm |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 220 |
I don't know specifically on Land Rovers but on other cars I have looked at then the car would start without the BMS reset but they didn't recommend leaving it too long till resetting it as you could damage your new battery.
25th Jul 2017 1:16pm |
