Home > Maintenance & Mods (L405) > L405 Tow Hitch |
Dte1 Member Since: 08 Apr 2015 Location: Worcestershire Posts: 6 |
Thanks for a quick reply. |
8th Aug 2017 12:14pm |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2152 |
I looked at the electrically retractable when I ordered mine, but understand that it's not just a lower noseweight off road, but a lower weight capacity too. That's definitely not what I want!
8th Aug 2017 2:15pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7760 |
As far as the manual goes - weight capacity is the same
8th Aug 2017 3:01pm |
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 184 |
I have the LR removable one. Square section male connector on the hook that slides into a square section female connector on the car - this has a rubber push in cover when the hook is not in place. Large 'L' shaped pin with R spring clip to retain it. Came in a little zip bag. You can adjust height as there are 4 bolts holding the towhook to the plate that is on the end of the male connector. 17 MY Corris Grey 4.4 VAB
15th Aug 2017 8:25pm |
How high is the top of the tow ball from the floor ?
15th Aug 2017 11:06pm |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 266 |
Any chance of someone with a LR removable tow bar for the 405 please posting some photos of the rear of the car with the tow bar removed and the rubber cover in place? I've seen the stock LR brochure pictures but would find it helpful to see a real world example.
16th Aug 2017 10:34am |
Alistair, Thanks for the copy of the manual from the 8th of August. The bit that I didn't see the first time that I read your scanned image was the bit that said: "Note: The powered tow bar option is limited to 1,000 kg for off-road use". I wonder what the mean by "off-road use"? At what point does a grassy field become rough enough to be considered "off road", especially with, say, a large and fully loaded horse box? This is the limitation that stopped me from buying one as I'm more likely to use it more frequently for off-road recovery, or retrieval of a trailer from a field than I am to use it on the road. PS: A friend was killed in a RTA, about 2 years ago, when his car was hit by a trailer that had became detached from a LR. This is why it's a bit dear to my heart and why I won't compromise on the strength of a tow bar. |
16th Aug 2017 11:16am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
On road you're getting a very straight pull. Off-road, the pull will be at all angles and often switching angles quickly. If your towing area is flat/smooth, it shouldn't be a problem. Also, the slower you go, the less stress, so low range and set it something like rock crawl if you get to anything uneven. |
18th Aug 2017 2:09am |
It shouldn't be a problem for those going to level and smooth campsites, with no traction problems but, for anyone using it as a Land Rover is intended, to have to say "sorry, I can't recover your Nissan Navara from that boggy field you've got it stuck in", or "that trailers going to have to stay where is is, because the field you've got it stuck in is a bit bumpy because my tow bar is too weedy and it might snap off" would be a bit rubbish!
18th Aug 2017 5:49am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
I'm not sure about using 'rock crawl' for towing, as this automatically puts the car on the high suspension setting, which having a trailer connected would block from happening. 'Grass gravel snow' might be better.
18th Aug 2017 11:57am |
I would upload a picture of the tow hook with rubber cover but can't get the upload to work! 17 MY Corris Grey 4.4 VAB
18th Aug 2017 5:37pm |
I’m looking for one of the adjustable height ones, but can’t find one anywhere. I can find the removable bit, but not the part that is mounted to the car. Does anyone know where to source one? |
10th Oct 2017 7:04am |
Looks like main dealer only - I've not seen one anywhere else - so maybe try Matfords or Dan ?
10th Oct 2017 7:58am |
Thanks Alastair, I shall follow those up. |
10th Oct 2017 10:25am |
