Home > In Car Electronics (L322) > Shocking standard stereo
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
What a total pile of crap the standard system in the vogue is , switching itself off , screen appears to have 4 colour settings which it decides for itself which it wants to use , the sound vanishes for no reason , the date randomly disappears , i could go on but it annoys the sh**e out of me 😠
Post #448974 24th Aug 2017 7:32pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
😡unreliable piece of Censored not thought out properly and doesn't intergrate with most other aftermarket stereos I'm seriously
considering ripping it all out this weekend all I have had is problems one unit failing one after another 😡
Post #448980 24th Aug 2017 8:11pm
bembo449
Wunt blame you pal , thow it does make you wonder why its so poor
Post #448982 24th Aug 2017 8:15pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Don't know why your sound system is so poor pal.
mines b Censored y great.
but then it is at least 12 years old. Rolling Eyes
Post #448988 24th Aug 2017 8:51pm
+15 years and all original kit still going strong, loud enough and clear enough. Radio/Tape/CD/TV and video (in motion, for passengers) if I want it, and original SatNav still fine.
Worth spending some time in the Left Rear cubby cleaning everything up, and making sure there is no damp back there. .
Post #448994 24th Aug 2017 9:17pm
bembo449
cleaning everything up ?? can you be more specific please pal
Post #449001 24th Aug 2017 9:58pm
mjdronfield
They are prone to damp and leaks in the rear left cubby where the amp, sat nav and tv etc are. The connector plugs and pins can get damp and corroded. Unplug each plug on the units, one by one, with the car turned off and dry them out or use switch cleaner etc.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #449022 25th Aug 2017 6:50am
bembo449
Ah i see ok pal , the dvd player is missing so i presume that wont affect it ??
Post #449078 25th Aug 2017 4:57pm
mjdronfield
Never had a DVD player fitted from factory so I hope it's not that being wired in that's done it. Though you could technically have one fitted as factory as part of the Autobiography options, with the screens in the front seat backrests.....
See how you go.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #449081 25th Aug 2017 5:33pm
p38arover
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
My Vogue's system is excellent. Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #449122 25th Aug 2017 11:47pm
bembo449
right folks , looking to test the system from the AMP this aft , what setting do I need to use on my multi meter ?
Post #449427 29th Aug 2017 1:03pm
p38arover
I don't know what you are intending to test with a multimeter.
I was an electronics tech and I'm not sure where I'd start with the symptoms you describe. I think I'd be searching the BMW forums to see if anyone else has similar symptoms on their vehicles. Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #449429 29th Aug 2017 1:15pm
bembo449
hmm but surely there is a way to test the amp and see if its functioning pal ?
Post #449430 29th Aug 2017 1:16pm
p38arover
Yes, but I'd use my audio oscillator and oscilloscope for starters.
About all you can check with a multimeter is cable continuity/resistance and supply voltage. Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #449431 29th Aug 2017 1:29pm
bembo449
ok , so if I get readings for them on every pin from the amp , does that not suggest its functioning properly ?
Post #449432 29th Aug 2017 1:31pm
