Home > Maintenance & Mods (L405) > Tailgate rubbing on D-pillars
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Only just noticed this, but the upper tailgate is pulled too tight against the D-Pillars on both sides and has worn a ridge in each.
Chatting through this with the workshop manager at the local dealer, I got the impression he had seen loads of these in the past.
Anything I should be concerned with when this gets fixed? Apparently the pillar trims will be replaced and the tailgate will need to be adjusted. 2016 SDV8 AB
Post #446114 29th Jul 2017 1:21pm
ABAB
Just to advise that this has now been fixed under warranty.
The D pillar finishers have been replaced and the upper boot spoiler (housing the high level brake light) adjusted so that it no longer touches the pilllars. 2016 SDV8 AB
Post #450524 11th Sep 2017 8:51am
England 2012 Range Rover Westminster TDV8 Santorini Black
good result. Thumbs Up .
Post #450575 11th Sep 2017 5:00pm
AMD
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Thanks for sharing, mine is the same. I will ask dealer to change and adjust along with a new gas strut which squeasl like a pig on closing. Current: 2014 FFRR SDV8 Autobiography with RSE
Gone: 2015 BMW F36 435d XDrive
Gone: 2015 BMW F10 M5 LCE
Gone: 2013 Evoque Dynamic for SWMBO
Gone: 2013 Porsche Cayenne
Gone:2011 4.4TDV8 Vogue
Gone:2006 Vogue SC
Post #450601 11th Sep 2017 8:02pm
pld118
I noticed the other day that one of our D pillars seemed a bit wobbly loose. Thought no more of it other than to plan to have it checked out. Wonder if that's the reason/ will check tomorrow...
Post #450606 11th Sep 2017 8:25pm
pld118
Think ours is afflicted on both D pillars from the 'wing tips' of the roof spoiler impacting with the pillars when the boot closes. See damage caused to the pillars on either side, as photographed this evening. Also tends to explain why the driver's side pillar feels a bit loose.
Driver's side:
Passenger side:
Post #450758 12th Sep 2017 10:04pm
pld118
I think TOPIX captures this issue. Can't access the full details as haven't paid for a subscription but the summary on TOPIX says the following:
"Tailgate Incorrectly Aligned/Fouls D Pillar Exterior Trims
A Customer may express a concern that the tailgate is incorrectly aligned or is touching the D pillar outer trims when closed.This version has been issued due to a change to the title and situation.
Global reference: LTB00926v2"
Post #451894 24th Sep 2017 8:18am
ABAB
Very helpful - thanks for the posting from Topix.
For some reason I donít understand, Iíve just looked again in Topix against my VIN and canít see a bulletin with this reference. I assume itís come from the ďtechnical bulletinsĒ section? 2016 SDV8 AB
Post #451904 24th Sep 2017 9:43am
pld118
Hi ABAB,
I'm not great at negotiating my way through TOPIx but didn't put a VIN in.
I just did a 'back to the start' open type search so typed in 2013 as a car year and then typed the word 'tailgate' in the search engine. It produced a lot of different tailgate related topics and this 2016 one was one of them (if that makes sense).
Really interested to know what the suggested action is though Thumbs Up
Post #451928 24th Sep 2017 2:45pm
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
