Home > Technical (L322) > The devil has taken over my RR TD8 2007
jfarrell32
Ireland
Tonight as we prepared to go to bed the devil seems to have taken over our RR. The horn started blaring and no matter what I did it continued intermittently. I tried spraying wd40 on the door locks and bonnet latch in case there was a sensor somewhere but with no success. Eventually I disconnected the battery and am now going to bed. Any thoughts or suggestions on the source of the issue would be very helpful. Crazy machine.......
Post #450954 15th Sep 2017 12:18am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
buy some ear plugs, i suspect it was getting cold and lonely Thumbs Up
Post #450972 15th Sep 2017 9:05am
nickt68
2015 Range Rover Vogue SE SDV8 Santorini Black
Did it stop when you unlocked it? I recently had problem with the alarm going off and it was diagnosed as a faulty bonnet sensor. Had this replaced and (touch wood) not had an issue since.
Post #450974 15th Sep 2017 9:19am
jfarrell32
Ireland
no! I tried turning on/off, short driving, open and closed all doors and bonnet. Eventually disconnected battery.......
Post #450982 15th Sep 2017 10:33am
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
The same thing happened to me after the AA man changed my battery, when we were manhandling the bonnet
into the service position and locked it, i noticed the bonnet was flexing quite a bit. So I suspect the switch plunger
wasnt close enough to the bonnet inner skin to set itself to the off position.
Anyway, later in the evening the same day the alarm kept going off, on a hunch I unplugged the bonnet alarm switch, sorted!!!.
Post #451034 15th Sep 2017 7:22pm
+1 for the bonnet switch, mine on the disco was playing up a couple of weeks ago, kept setting the alarm off! There is nothing that can't be fixed with a hammer😜😜
Post #451036 15th Sep 2017 7:48pm
If not the bonnet sensor, try locking the car with a double press, to deactivate internal sensors.
I had a big (and I mean big) spider running around in the car after shifting some old stuff for my father, kept the alarm going off middle of the night when "he" was moving about. .
Post #451043 15th Sep 2017 9:26pm
A1GSS
^+1
Was the bonnet sensor on mine. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #451061 15th Sep 2017 11:19pm
rar110
I also vote bonnet switch. In my case the plastic bracket holding the switch had cracked which allowed the switch to drop and simulate the bonnet being open. ______________________________
Post #451088 16th Sep 2017 11:28am
jfarrell32
Ireland
Guy in the local garage fixed it - I was told bonnet sensor but now the horn does not work. Why would disconnecting the bonnet sensor stop the horn from working?
Post #451124 16th Sep 2017 6:08pm
Had a look at the wiring diagrams for '02 - '05 (so might be different on your later model), the horns and the alarm system do not appear to be connected in any way.
Worth checking fuse 10 and 53 (related fuses for above model years) for horns.
What exactly did the "guy at the local garage" do ? .
Post #451146 17th Sep 2017 12:02am
