Home > General (L405) > Speed Cushions |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2152 |
Massive clearance on the Disco I have, however, been told that always hitting the inner tyre walls with these things can ultimately result in tracking issues; not sure how much truth there is in that one yet.
16th Sep 2017 4:36am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Personally i dont slow down for speed bumps , the cushions you show i just place the car in a way to avoid 90% of them and have been doing so for 2 years now in my RR without obvious or apparent issues. Just another bonus of driving a RR. 2015 4.4 AB
16th Sep 2017 9:40am |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Ever since these monstrosities started breeding, I've always straddled the speed cushions (ooh er missus) with every car (owned and work vehicles) without any geometry or tyre issues and the Fatty is no exception.
16th Sep 2017 10:25am |
DangerMouseUK Member Since: 03 May 2015 Location: London Posts: 69 |
Thats what I read and thats what I started wondering if there was any truth in that. I mean I never go over the posted speed limit when attacking these things and normally go 20-30% slower just as a precaution because some of them in London look pretty ropey and decayed. I read elsewhere that guidelines state "official" ones can't exceed 100mm or 10cm so thats something reassuring I guess. |
16th Sep 2017 2:16pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
There should be plenty of ground clearance. The track should be wide enough to drive over them without too much impact on sidewalls, though 22" wheels will clearly be more sensitive than 20". I think the problems are more for 'ordinary' cars with low profile tyres. Only Range Rovers since 1988 |
16th Sep 2017 2:47pm |
Hi CS, according to LR UK;
16th Sep 2017 2:52pm |
The 322 is a bit narrower and I find that driving over cushions near me hardly touches the wheels, the wider 405 should be better. The ground clearance is such that there should be no risk of hitting the bodywork, the way there might be in say a Ferrari. As someone else has said the cushions are meant to allow an ambulance to drive over without jolting a patient inside, so a RR with a similar track ought to be able to do that too. That said I am not driving over them every day, and cushion design may vary. Also much of Edinburgh is now 20mph so the impact will be less at the lower speed. You can't go wrong putting a wheel on the middle of the cushion with the other on the flat road, that is what is recommended for drivers in general, but I regard that as needless discomfort in the context of my 55 profile tyres. I have not heard of RRs having problems with inner sidewalls, other than, I think, for some users of Cooper Zeon LTZs, which I had associated with those tyres rather than driving habits over speed cushions.
16th Sep 2017 3:30pm |
