Home > Technical (L405) > Intelligent Stop / Start
Page 2 of 3 <123>
emilio
Malta 2012 Range Rover Westminster TDV8 Orkney Grey
dpf's, catalytic converters - they all break down and need servicing every set number of miles. is that the solution? plus the waste more fuel apart from the co2 they produce to make these things in the first place.
15 years ago i had a mk4 golf 1.9 tdi - 60mpg without even trying, no matter the congestion or the road that thing will get 60mpg(keep in mind i drive preety much pedal to the metal). comparable engine nowadays is the 1.6 tdi both 110bhp-ish both diesel and id be lucky to crack 40 in the new 1. just for comparison i get 33mpg out of my 640d, 30mpg out of a 320d and 19mpg out of the sdv8. my drivving style aint changed.
Post #452269 27th Sep 2017 5:30pm
GGDR
My POV is air quality. The topic quickly mushrooms..
In my opinion we need stop/start. Speed humps removed. Euro6 lorries and buses. Hybrids. Then Hybrids with battery only range. Then battery-only. And anything else too. It's all a journey towards less air pollution and for sure only one initiative won't do it. The way to fix any big problem is divide it down into smaller problems that can be fixed.
To your point on MPG - engines are a trifecta of POWER vs EMISSIONS vs FUEL CONSUMPTION. One affects another. The manufacturers have been fiddling the books anyway so who knows what numbers are correct.
Does stop/start reduce traffic light pollution?
In my opinion, yes.
Can we solve the bigger issues on this forum?
Absolutely not.
And we all drive Range Rovers which doesn't help. I'll be the first to admit that.
Greg. Cheers, Greg
Post #452273 27th Sep 2017 6:05pm
emilio
yeah we probably shouldnt drive rovers, not if were concerned with the environment
Post #452274 27th Sep 2017 6:09pm
Gruute
Belgium
About CO2 https://www.maximumyield.com/the-missing-ingredient-co2/2/1214
The goal of CO2 enrichment is to reduce the time from seedling to harvest and to speed up growth and increase yields. Plants grown with elevated CO2 levels are better able to resist insects and diseases, which makes for healthier plants. For example, in a recent study lettuce was grown in a greenhouse with ambient air versus lettuce grown in a greenhouse with enrichment.
The test showed the lettuce grown in the greenhouse with ambient air was ready to harvest in 59 days. In the greenhouse with CO2 enrichment, the lettuce was harvested in 48 days. By weight, the CO2-enriched greenhouse lettuce weighed 30% more. In studies here at our farm, we have found that by supplying tomato plants with elevated CO2, those plants produced 20% more tomatoes than plants that did not receive the elevated levels. By harvestable weight, the plants receiving more CO2 out-produced those without by 25%.
Tests performed on strawberries showed that strawberries grown with elevated levels of CO2 contained more sugars and physical mass to support a greater number flowering sites. The fact that there were more flowering sites led to a greater number of strawberries being formed, which led to more overall production. 2017 Range Rover Vogue TDV8 silicon silver
2011 Defender 90 2.4 TDCI Nara Exclusive
2008 Porsche 911 997 4S Black/black
1970 Porsche 911T 2.2 in restauration
1980 Toyota Land Cruiser BJ40 concours winner
Post #452293 27th Sep 2017 7:18pm
Gruute
Belgium
Start/stop is bad for your engine. What's worst than stop an engine running when it's hot. Turbo doesn't get cool oil and what about cilinderheads?
Also cross a busy road it's dangerous when the engine swtiches off and takes that extra second to re-start. It doens't help you to cross safe a road.
In terms of cost. Does LR counts the engine switch off cycles? At Volvo you have to go the garage for a new battery after a number of engine starts. And the second time also for the starter engine. ££££££ 2017 Range Rover Vogue TDV8 silicon silver
Post #452297 27th Sep 2017 7:29pm
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
So the overall consensus on stop / start so far seems to be negative (probably not a surprise to me).
The sister forum for the Evoque refers to a technique for disconnecting a secondary battery to disable the stop / start. I presume this might also work for the 405 - anyone tried it? 2016 SDV8 AB
Post #452430 29th Sep 2017 9:36am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
The best way is buy a petrol engine Thumbs Up Thumbs Up oh and spec without start stop
Post #452460 29th Sep 2017 5:10pm
emilio
thats what i plan to do next time, just hope they dont fit particulate filters to petrols now
Post #452462 29th Sep 2017 5:16pm
CS
Are they not all stop start now? Only Range Rovers since 1988
Post #452471 29th Sep 2017 7:14pm
Vogue
I used to hate stop start, but now I have one avoiding it cutting in is easy.
If I just hold it lightly on the brake - it doesn't stop the engine. The engine stop only cuts in on mine on full depression of the brake pedal.
You can either control it by judicious use of the pedal or just turn it off.
If anyone has ever driven a pig with stop start - now that is feckin annoying Evil or Very Mad 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #452484 29th Sep 2017 9:33pm
i had it in a loan car recently and found it un-nerving, kinda felt like you were loosing control of the vehicle.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #452489 29th Sep 2017 9:38pm
Fat Wolfie
Guess it's just what you get used to.
The FF has stop start and the Abarth doesn't. I now find it strange in the Abarth that when I'm stopped at lights the engine is still running Laughing
Post #452510 30th Sep 2017 8:56am
DangerMouseUK
United Kingdom 2017 Range Rover Autobiography SDV8 Farallon Black
Has anyone’s stop start simply stopped working without any warnings or anything at all ?
Post #453355 8th Oct 2017 2:54pm
Steve j
United Kingdom 2013 Range Rover Autobiography TDV6 Luxor
Hi Guys not the usual start stop question,I have a 2014 MY, intelligent start stop does not work until I remove battery terminal then replace it ....the intelligent stop start works fine , I then put it away for the night next day will not work, again ...remove battery terminal then replace it works again fine, I have new batteries so not those, Any ideas??
Regards
Steve
Post #472147 11th Mar 2018 5:15pm
Steve j
Think I have sorted it,taken it out of auto select to manual and it's now working fine Thumbs Up
Post #472170 11th Mar 2018 7:59pm
Page 2 of 3 <123>
