Home > Technical (L322) > Range Rover L322 2005 height Calibration |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Welcome to the forum.
27th Sep 2017 6:10pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
err, it is in the correct section... ... - .- -.
27th Sep 2017 6:27pm |
Stan, it appears Martin beat you to it:
27th Sep 2017 6:56pm |
i'm slacking
27th Sep 2017 8:06pm |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
Here, the heights for 22" if it helps.
28th Sep 2017 1:56pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
But measurements for calibration are always taken from the hub centre (IID/AllComms), and therefore the same for any wheel/tyre combination .
28th Sep 2017 7:16pm |
Joe90,
29th Sep 2017 7:40am |
i cant see why pre 2006 FF's would be any different to the newer ones..
29th Sep 2017 7:59am |
I cannot remember which named tool they were using (but was range rover specialist garage), but i was there when they needed to input numbers and on the earlier cars on there tool it needed to be measured from the bottom wheel. which is why i had the sheet above.
29th Sep 2017 8:17am |
This is causing confusion.
29th Sep 2017 11:22am |
i thought the same Tim ... - .- -.
29th Sep 2017 12:15pm |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
Hi johnmaambo and welcome to the forum.
29th Sep 2017 2:02pm |
@ johnmaambo
30th Sep 2017 11:54am |
Hi Guys,
7th Oct 2017 1:19pm |
