Home > Maintenance & Mods (L322) > No heat from heater??
Sandyt
Hi all everything is working fine apart from no heat coming from the heater on auto or max - air lock? if so how to get rid?
Post #453360 8th Oct 2017 4:17pm
Dolphinboy
Could be your blend (?) motors not opening the flaps due to detritus jamming them up... or an air lock as you say..... or the thermostat not opening properly?
Post #453441 9th Oct 2017 2:16pm
bertie1
United Kingdom 2004 Range Rover Vogue Td6 Adriatic Blue
have you turned the knob in middle to red if not it blows cold in both front and back
Post #453709 11th Oct 2017 1:34pm
Sandyt
Right well in true Rangie style it couldn't be just one thing so the thermostat wasn't opening properly and the blend motor is stuck or at least has limited movement so replacing all no point in my mind freeing things up at 10 years old I just change the parts Thumbs Up
Post #454631 20th Oct 2017 9:45am
