Home > Maintenance & Mods (L322) > Range rover l332 aircon
banser
Ireland 2005 Range Rover Vogue Td6 Stornoway Grey
Hi my 2006 range rover l332 has started blowing vapour out through airvents she the aircon is switched on does anybody know the cause or cure for this thanks in advance
Post #454103 15th Oct 2017 11:49am
holidaychicken
If it is still cold, don't worry - mine does it from time to time. basic description below. If it does it for a few days and then stops being cold then you have problem.
http://products.geappliances.com/appliance...ntId=16744
Post #454140 15th Oct 2017 10:41pm
banser
I searched for an answer to this on landrovers forum and apparently it's very common its condensation in aircon the drain tubes become blocked just don't know where the drain tubes are on range rover
Post #454157 16th Oct 2017 7:08am
Weegie
Two tubes, one hanging down either side of the gearbox. John
GAP iiD BT
Post #454160 16th Oct 2017 8:59am
banser
Thanks will have a look when weather improves
Post #454164 16th Oct 2017 9:08am
holidaychicken
When i have been parked for a while with the engine running and the aircon on I get quite a puddle underneath from the drain tubes
Post #454170 16th Oct 2017 9:29am
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
Rolling with laughter Rolling with laughter Rolling with laughter Good luck with that........
I've had the same with mine from time to time, try it with the recirculation in different positions and see if it makes any difference.
Post #454341 17th Oct 2017 9:25pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
I always thought that was a Range Rover just marking it's territory!!
Post #454512 19th Oct 2017 9:17am
Laughing ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #454513 19th Oct 2017 9:20am
