Home > Technical (L322) > rear wiper.....problems! |
Re-Visit pulling the fuse and re-inserting. Try it with the ign on and the switch on and with the switch off.
5th Jan 2011 3:31pm |
tommac22 Member Since: 10 Nov 2010 Location: devon Posts: 55 |
thanks dan- will have a look tonight! |
5th Jan 2011 5:59pm |
Fuse 41 I think - just sorted mine. Took about 5 goes though! |
5th Jan 2011 6:24pm |
right. I had a go at pulling the fuse with various combinations- ignition one, off, wiper switch set on /off etc. has nt made a difference sadly. Im edging towards replacing the wiper stalk/switch- does anyone know how easy it is to access this- cowl off under the wheel or air bag/wheel off etc? the stalk is about £50. |
11th Jan 2011 2:30pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
Take the trim off first to the wiper, is the tube running through the arm forms a leak the motors get soaked and sieze up. If there is water in the trim then this may suggest this is the problem, or eliminate it at least.
11th Jan 2011 3:05pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3074 |
my rear wiper worked perfectly well until coming back last week from Austria. It then just hung down at the 6 O'clock position. I followed RRUk's excellent photo instructions and removed the whole rear wiper unit. It was simply the nut had come loose. I tightened this back up and it works fine again. However the spray mechanism does not (it hasn't worked from purchase). I took the opportunity to clean out the ridiculously basic spray mechanism in the arm and checked the water delivery through the pipes whilst unattached to the motor. Despite sucking and blowing no water came out. could it be a b*ggered non-return valve? also, couldn't find where the pipe went from the front tank. only one pipe came out and went to the front sprayers only. Anyone know where the rear water pipe goes from and to? (can't get RAVE to work at the mo as on a mac - don't got there Dan!! ) |
11th Jan 2011 3:21pm |
