Home > Technical (L322) > Td6 FBH
Paul thornton
Td6 FBH
Anyone know where it's located under the bonnet.
Had a quick look earlier but can't seem to see it...
Post #457044 12th Nov 2017 4:37pm
near side front, above/inside the wheel arch.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #457045 12th Nov 2017 4:43pm
Paul thornton
Thanks.
Just need to figure out why it doesn't work now!
Post #457050 12th Nov 2017 5:24pm
loads of info re the fbh on the forum Paul, have a search Wink ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #457052 12th Nov 2017 5:31pm
Paul thornton
Thanks.
The thing kicks in and I've found the exhaust for it which blows slightly warn air. It runs for 4 or 5 mins then stops and doesn't actually produce any heat in the cabin...
Post #457055 12th Nov 2017 5:41pm
The fbh only cuts in at air temperatures lower than about 5C. If it cuts in then goes off after a few minutes it’s possible it working correctly depending what the outside air temperature happens to be.
Also the fbh doesn’t heat the cabin directly. It heats the engine coolant in a limited amount of pipe work that serves the main heater battery beside the heater blower so it does take a few minutes to produce warm air into the car. Mine produces reasonably warm air after about half a mile from cold. Thumbs Up
Post #457058 12th Nov 2017 6:47pm
Paul thornton
I'm lead to believe that if I set the timer it should come on at temps below 15 degrees C.
Although I can physically hear it running, there is no smoke and it will cut out after a few minutes.
I tried it the other morning when it was about 2 degrees outside and got the same results.
I'm guessing the glow plug isn't working or something along those lines.
Post #457061 12th Nov 2017 6:53pm
Thumbs Up I don’t use the timer just outside air temp.
Should have been working fully at 2C. Your probably right it may just need a good service. Don’t forget the fbh oil pump which can fail or corrode away to dust.
Post #457064 12th Nov 2017 7:12pm
Paul thornton
Where is the pump located?
Post #457065 12th Nov 2017 7:34pm
Quote “ The fuel pump for the FBH is located in one of the most inaccessible places on the car, behind the upper wishbone of the RHR suspension. One can just about get a hand or finger to it to test if it is running/ticking. If you are really in the mood you can (CAREFULLY!) drop the subframe @ 2in on that side for better access. “
Post #457095 12th Nov 2017 10:39pm
