Home > Technical (L322) > TD6 Suspension Fault Code
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
Does anyone know what the following TD6 (2006) suspension fault code is all about?
C1A07-62 (6Cool Cross articulation - algorithm based failure - signal compare failure
Could this be triggered by a faulty height sensor, and if so, which one?
(don't know where the happy face came from - should be (sixty eight) 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #457171 13th Nov 2017 8:50pm
Have you had a look at your height sensors, usually one has "given way" and is no longer linked to the suspension.
If none appear broken then you will have to do some more investigation, maybe disconnecting each in turn.
Cool you need to add spaces 8 ) .
Post #457181 13th Nov 2017 10:06pm
