Home > Technical (L405) > Does the AB remote heater heat up the engine? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
yes it does ... - .- -.
16th Nov 2017 10:13pm |
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 395 |
But this morning it didn't do anything. I guess that after not using the car for 3 days it decides that the battery voltage is/will be too low if it carries on the auto cycle so decides to stop working.
17th Nov 2017 7:07pm |
Its an Engine pre-heater the cabin heating is an added benefit in a fullfat.
17th Nov 2017 11:42pm |
Time for me to RTFM |
18th Nov 2017 9:27am |
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 |
Being pedantic, it's the coolant that is being heated. not the "engine". The main mechanical parts of engine, and the oil won't get anywhere near their operating temperature. |
18th Nov 2017 9:59am |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 |
The inside of mine gets steamed up quite bad when using it! 2010 defender utility
22nd Nov 2017 8:34pm |
You’re lucky mines packed up after working just the once. Cant be arsed to take it to a dealer. |
22nd Nov 2017 9:27pm |
WBSam Member Since: 04 Jan 2016 Location: aberdeen Posts: 3 |
plz where can i order oxygen sensor for DIESEL L405 2013? |
27th Nov 2017 1:56pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3689 |
Main agent 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
27th Nov 2017 4:23pm |
