Home > Technical (L322) > 2011 coolant tank
Baltic Blue
2011 coolant tank
Please can someone add a photo of the expansion tank on a 4.4 tdV8.
I have just been checking the antifreeze level on mine and it seems very distorted in shape, as if it might be being sucked in over time?
It doesn’t alter with the top on or off, so not under pressure?
Thanks
Post #457709 18th Nov 2017 1:20pm
mpirie
It is a very strange shape for an expansion tank.
It has several baffles internally making it virtually impossible to reach the bottom if you were to try and clean it.
I don't think it changes shape over the operating temperature range.
Mike
Post #457719 18th Nov 2017 2:55pm
here you go Mike..it does indeed look 'sucked' in.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #457721 18th Nov 2017 3:03pm
Baltic Blue
Mike & Stan,
Thanks for your replies.
Stan, mine looks identical to yours,
Cheers
Panic over 😁👍 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #457724 18th Nov 2017 3:10pm
mpirie
Stan,
Is that dirt i see in the webbing of the off-side air filter housing?
If so, we may have to review your forum eligibility since you're clearly letting your car get dirty......against membership rules Whistle
Mike
Post #457725 18th Nov 2017 3:12pm
Baltic Blue
Rolling with laughter Rolling with laughter
That is why I didn’t post a picture of mine first, just in case some eagle eye spotted a speck of dust .
Cheers. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #457727 18th Nov 2017 3:17pm
nino_nino
Here You go BB,
Post #457728 18th Nov 2017 3:18pm
i have been clearly caught out Crying or Very sad
next time i'll keep my bonnet shut Laughing
[see what i did there, bonnet-mouth]
Mr. Green ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #457729 18th Nov 2017 3:19pm
Baltic Blue
Thanks Nino,
Did you clean it specially to take the photo?? Bow down Thumbs Up G reg 2.5VM Vogue Portofino red 1991- 1999
Post #457731 18th Nov 2017 3:23pm
its un-canningly clean Shocked Wink ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #457733 18th Nov 2017 3:30pm
nino_nino
She likes it that way Very Happy , keep her happy you'll be happy .
I did clean the tank after getting low coolant level warning. used petrol and household degreaser. saved me from having. to buy new one. where i live that is major hasel. Very Happy
Post #457734 18th Nov 2017 4:04pm
mpirie
I still have the remnants of oil from the cooler problem in my header hence no picture.
I'd definitely get kicked out of the club if I posted a picture of mine. Big Cry
Mike
Post #457801 19th Nov 2017 11:18am
Baltic Blue
At least they are all roughly the same distorted “sucked in “ shape.
I wonder what shape a new one is??
Someone changed one recently, because the internal float switch failed, so that one should be clean enough for a photo Rolling with laughter
I think it was Zeppfish??
I will replace mine “when” it fills up with oil Big Cry Big Cry
Post #457807 19th Nov 2017 11:47am
nino_nino
mpirie, I had oil in my to from the leaking oil cooler. first time coolant was low enough to trigger the warning, float got stuck on the bottom and i had low coolant level on all the time. remedy was to clean the expansion tank, pictures here-
http://www.fullfatrr.com/forum/topic20913.html.
it is easy job.
nino
Post #457808 19th Nov 2017 11:51am
nino_nino
BB, we need to see yours yet. Laughing
Post #457809 19th Nov 2017 11:59am
