Home > Maintenance & Mods (L322) > Possible steering rack |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2227 |
I had that and it turned out to be rear hub bushes allowing minor rear wheel steer - have you had 4 wheel alignment on a Hunter or similar would be a good place to start |
23rd Nov 2017 9:57pm |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 354 |
I'm fairly sure that they are all the same through all years.
23rd Nov 2017 10:50pm |
Blair Member Since: 03 Apr 2017 Location: Suffolk Posts: 72 |
Thanks for the tips
24th Nov 2017 9:38am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
Had one replaced, original quote was an absolute joke. Eurocarparts do gen zf units brand new for much, much cheaper. I went with a recon unit with full guarantee for even less. my Indy did it in less than factory time. |
24th Nov 2017 10:46am |
My original quote from my usual specialist (very good, bit pricey) was £2700+VAT!
24th Nov 2017 10:55am |
Spoilt for choice, iirc mine was supplied and fitted for £1060, originally £3200 + vat+ fitting |
24th Nov 2017 11:01am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Check that the nut that fixes the lower steering column onto the steering rack splined shaft is fully tightened up. If the nut loosens ever so slightly it can lead to a slight feeling of loose play in the steering wheel. I had a similar thing on my FF which was cured by nipping the nut up.
24th Nov 2017 2:23pm |
