Home > Maintenance & Mods (L322) > Forward Alert Not Available
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Whenever I start my car, I get an amber triangle warning: Forward Alert Not Available.
After a couple of seconds the warning goes. And no fault shows - even when I select to see any.
I've got Forward Alert switched off in the vehicle setup. But get the same even when I switch it on.
What's confusing me isn't the warning - I can get the forward alert checked - but do I actually have a problem with it or not?
Surely if it is faulty, the error would show up when I look at show warnings. What do I put here then?
Post #458668 27th Nov 2017 10:51am
GraemeS
Check engine bay fuse 17 (10) in case it has blown.
Post #458717 27th Nov 2017 8:34pm
GAC23
I will. Thank you. What do I put here then?
Post #458724 27th Nov 2017 9:09pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Might get laughed at here, but I’m sure I got that message when I bought mine a few years back and it was the air compressor that was at fault. I’m trying to remember if it was that message that showed, and why it was compressor, if I remember I’ll write back. Embarassed
Post #458744 27th Nov 2017 11:42pm
GAC23
Post #458748 27th Nov 2017 11:57pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Does your auto cruise still work?
I get that error message if driving in snow and there is a build up of snow on the front of the car and it stops the auto cruise from working.
Ian
Post #458777 28th Nov 2017 9:46am
GAC23
I don't know - only because I don't use it.
Will give it a go later, thanks Smile What do I put here then?
Post #458778 28th Nov 2017 9:51am
GAC23
Ian
Just tried it ... the adaptive cruise does work and slowed me down as the car in front did. What do I put here then?
Post #458828 28th Nov 2017 3:20pm
GAC23
Have an IID tool coming.
Will be keen to see what it report. What do I put here then?
Post #462890 1st Jan 2018 3:16pm
