Home > Technical (L322) > Gearbox - AGAIN! |
TerryT-J Member Since: 02 Sep 2013 Location: Johnston, Pembrokeshire Posts: 86 |
Well here I sit waiting for the RAC. Clunks and vibrations from underneath, trans. Failsafe prog on dash and come to a halt. No drive forwards or reverse. Switch off engine, restart, forward drive but no reverse. Not going to risk moving. This is a replacement box fitted 3 years ago. 30 000 miles. Not happy. Time for a total change of car I think.😡 |
17th Nov 2017 8:46pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Sounds like torque;i just revised mine. 2010 3.6tdv8 180k km.
17th Nov 2017 8:53pm |
Had to put transfer box in neutral to get it off breakdown truck. Seemed to be jammed n mater what position selector was in. Once off and fuse removed did not want to go backwards when reverse selected but would go forward! Would torque converter jam it up? |
17th Nov 2017 9:41pm |
No, no warning at all! |
18th Nov 2017 10:46am |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 843 |
I read posts like this and it once again puts me off buying a FF.........😩 |
18th Nov 2017 5:30pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Not sure if this is your cause but some information here.
18th Nov 2017 5:46pm |
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 |
Seems to me like these gearboxes are very poor, every one Ive owned (in either BMW or RR) have failed. Yet the Mercedes ones Ive never had a problem with |
18th Nov 2017 8:06pm |
I get the impression the GM boxes are quite poor but the ZF boxes can at least be reasoned with |
18th Nov 2017 9:57pm |
Well I got the FF back today, gearbox was re-built. Problem was an output shaft which is hollow that had what i can only describe as a spiral shear. It looked like a bog roll tube that had been opened up! I'm trying to get a photo. |
7th Dec 2017 5:32pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3059 |
Rrphil has highlighted this before - have a search and you will find a great photo of exactly this on one of his posts. |
7th Dec 2017 6:42pm |
Here is one of them, i do recall reading it now you say it.
7th Dec 2017 8:18pm |
